Hello
I would like to link an iProperty to a dimension of my room (e.g. length of a profile).
Is this possible? If so, how?
Hello
Hello
Yes, you can, you need to create a property and in the "Value/Text Expression" cell you click on the dimension. This will automatically fill in your property.
Kind regards
Hello
Uh, jmsavoyat, that's for Solidworks and now he's asking the question for Inventor...
First hack found, I went through iLogic:
If 1 Then
iProperties.Value("Project", "Description")="Long "&d4
End If
However, iProperties.Value("Project", "Description")="Long "&d4&"mm" does not work.
I haven't delved into the parameters of the function, including "Project", "Description" is the property I'm editing, "d4" the dimension I'm assigning.
Nice thing, "d4+d25" works.
Oops! Excuse me! I hadn't paid attention.
Hello
You can avoid going through iLogic by following these 3 steps
1°) name the call number with the syntax below (easier to find the call number to export).
2°) check the boxes in Settings
3°) follow the syntax to copy the value in the iproperties
Value =<name of the dimension>
Be careful not to put any space.
