Welded parts list
Hi all
My question of the day; How to remove this " <1> " at the end of the welded part name
Capture d’écran 2026-01-08 113137
Hello @ronathan
You tried by the property I guess.
The 1 comes when there are two?
No, even with one body.
The qty is the number in parentheses.
Between <> it is the number of the article, in () it is the quantity. For example, if there is a repetition of bodies. For my part I don't have the <> (I don't know why)
This text comes from the options chosen here:
Not sure that this number can be removed to be tested with a few tries (depending on SW version possible change)
None of the checkpoints change this display of <>
I've tried several modifications in the options and I can't get the <>. I think there must be a file like calloutformat somewhere
Hello
According to the Solidworks help, it is not possible to hide the instance number as long as there are (or have been) several occurrences of the same component in the assembly:
https://my.solidworks.com/reader/onlinehelp/2021%252Fenglish%252Fswconnected%252Fswdotworks%252Fc_component_instance_numbers.htm/component-instance-numbering-in-assemblies?lang=de
Yes, so why don't some people have these instance numbers <>.
@Le-Bidule I haven't modified this file and I recently reinstalled the software so this file is original.
@ronathan
I have them these <>
I tried to remove them without result
However, in this old topic there is the post of @stephane_GUINOT in which we can see his list of welded parts without <>
https://forum.mycad.visiativ.com/t/proprietes-de-la-liste-des-pieces-soudees/110339/21?locale=fr&lang=fr
By renaming it replaces them with parentheses at home, and I no longer have <>
