Lists of bodies in a mass-welded construction
Hello
In my list of bodies of a welded construction which is a MEP I do not have access to the mass of the bodies:
In column properties I have only materials or quantity
How to bring the mass in addition to the materials or quantity that appear well in column
Hello
This parameter is found in the properties of the bodies in the soldered list.
Right-click on body -> Property -> in the property summary tab there will be all the existing properties.
All you have to do is select this  property in the table column
You can add a subject  column in your table template.
Cdlt
I tried but from the list (which is empty) I can only add the weight of the part and not the bodies
Good evening Olivier
I think the problem comes from the fact that your welded construction is actually a single volume.
If you want each element to be considered as a piece, you have to uncheck ""Merge bodies"".
On the other hand, it must cause you other problems if the welded construction is not totally constrained automatically by the function that generates the welded construction.
The mechanical-welding aces will give you the right information.
Kind regards
Hello
In reality it is not a welded construction but an import of a step
The bodies are not merged, some are even disjointed.
Can the pb come from these disjoint bodies (they are not connected to any other body)
Cldt
Hello
The problem with WWTPs (if I understood correctly) are  only  surfaces (so hollow structures without matter, which also means without mass).
If you want this to function, you have to do a function recognition so that you have full volumes and this for all the objects, which is quite long.
In conclusion: take a cross-sectional view and pass all your ASM with the horizontal vector of the Gizmo. If you no longer have any hollow structure (i.e. only full volumes I insist) then you will have the total mass and the mass of each element constituting it.
Kind regards
PS: I hate ;-( ;-(   the STEP that we are given on the forum to help solve PB because we have to do precisely this tedious conversion which does not work 100% and this especially to make simulations.
@ Zozo
there are at least 2 of us for the step ;-)
For file exchanges I much prefer the Parasolid native solidworks file
Hello Olivier,
The Step must be converted into a welded construction.
Soliworks then creates welded part folders.
It is then possible to add the mass variable in all welded item lists.
Kind regards
