Macro conversion of welded bodies to step
Hello everyone, I hope you are well,
I take the liberty of writing a message because I can't find the solution on solidworks 2025.
I'm trying to find/create a macro (because I don't know how to do them) in order to transform all the individually welded mechanical bodies into parts in STEP format.
Ideally by taking the name of the body and the quantity of the body.
example: if my body is called " Marche3 (8) " that the step of this piece is called "Marche 3 - qty.8" and that it registers only once not 8.
Could you help me create a macro like this?
Thank you all
Hello
You have the possibility to register each body independently with insertion/function/save bodies. Then if you have the MyCAD suite you can use Batchconverter and turn them into a step.
I don't use macros so I can't give you information or submit one to you.
Here is a way to record each body of construction welded in part, modifying it perhaps possible to save in step.
'Copyright(C) 2025 Xarial Pty Limited
'Reference: https://www.codestack.net/solidworks-api/geometry/insert-bodies-to-part/
'License: https://www.codestack.net/license/
Const CUT_LIST_PRPS_TRANSFER As Long = swCutListTransferOptions_e.swCutListTransferOptions_FileProperties
Const OUT_DIR As String = ""
Sub main()
    Dim swPart As SldWorks.PartDoc
    Set swPart = swApp.ActiveDoc
    Dim vBodies As Variant
    vBodies = GetSelectedBodies(swPart.SelectionManager)
    If IsEmpty(vBodies) Then
        vBodies = swPart.GetBodies2(swBodyType_e.swSolidBody, True)
    End If
    Dim i As Integer
    For i = 0 To UBound(vBodies)
        Dim swBody As SldWorks.Body2
        Set swBody = vBodies(i)
        If False <> swBody.Select2(False, Nothing) Then
            Dim outFilePath As String
            outFilePath = GetOutFilePath(swPart, swBody, OUT_DIR)
            Dim errs As Long
            Dim warns As Long
            If False <> swPart.SaveToFile3(outFilePath, swSaveAsOptions_e.swSaveAsOptions_Silent, CUT_LIST_PRPS_TRANSFER, False, "", errs, warns) Then
                swApp.CloseDoc outFilePath
            Else
                Err.Raise vbError, "", "Failed to save body " & swBody.Name & " to file " & outFilePath & ". Error code: " & errs
            End If
        Else
            Err.Raise vbError, "", "Failed to select body " & swBody.Name
        End If
    Next
End Sub
Function GetSelectedBodies(selMgr As SldWorks.SelectionMgr) As Variant
    Dim isInit As Boolean
    isInit = False
    Dim swBodies() As SldWorks.Body2
    Dim i As Integer
    For i = 1 To selMgr.GetSelectedObjectCount2(-1)
        Set swBody = GetSelectedObjectBody(selMgr, i)
        If Not swBody Is Nothing Then
            If Not isInit Then
                ReDim swBodies(0)
                Set swBodies(0) = swBody
                isInit = True
            Else
                If Not Contains(swBodies, swBody) Then
                    ReDim Preserve swBodies(UBound(swBodies) + 1)
                    Set swBodies(UBound(swBodies)) = swBody
                End If
            End If
        End If
    Next
    If isInit Then
        GetSelectedBodies = swBodies
    Else
        GetSelectedBodies = Empty
    End If
End Function
Function GetSelectedObjectBody(selMgr As SldWorks.SelectionMgr, index As Integer) As SldWorks.Body2
    Dim selObj As Object
    Set selObj = selMgr.GetSelectedObject6(index, -1)
    If Not selObj Is Nothing Then
        If TypeOf selObj Is SldWorks.Body2 Then
            Set swBody = selObj
        ElseIf TypeOf selObj Is SldWorks.Face2 Then
            Dim swFace As SldWorks.Face2
            Set swFace = selObj
            Set swBody = swFace.GetBody
        ElseIf TypeOf selObj Is SldWorks.Edge Then
            Dim swEdge As SldWorks.Edge
            Set swEdge = selObj
            Set swBody = swEdge.GetBody
        ElseIf TypeOf selObj Is SldWorks.Vertex Then
            Dim swVertex As SldWorks.Vertex
            Set swVertex = selObj
            Set swBody = swVertex.GetBody
        End If
    End If
    Set GetSelectedObjectBody = swBody
End Function
Function Contains(vArr As Variant, item As Object) As Boolean
    Dim i As Integer
    For i = 0 To UBound(vArr)
        If vArr(i) Is item Then
            Contains = True
            Exit Function
        End If
    Next
    Contains = False
End Function
Function GetOutFilePath(model As SldWorks.ModelDoc2, body As SldWorks.Body2, outDir As String) As String
    If outDir = "" Then
        outDir = model.GetPathName()
        If outDir = "" Then
            Err.Raise vbError, "", "Output directory cannot be composed as file was never saved"
        End If
        outDir = Left(outDir, InStrRev(outDir, "\") - 1)
    End If
    If Right(outDir, 1) = "\" Then
        outDir = Left(outDir, Len(outDir) - 1)
    End If
    GetOutFilePath = ReplaceInvalidPathSymbols(outDir & "\" & body.Name & ".sldprt")
End Function
Function ReplaceInvalidPathSymbols(path As String) As String
    Const REPLACE_SYMB As String = "_"
    Dim res As String
    res = Right(path, Len(path) - Len("X:\"))
    Dim drive As String
    drive = Left(path, Len("X:\"))
    Dim invalidSymbols As Variant
    invalidSymbols = Array("/", ":", "*", "?", """", "<", ">", "|")
    Dim i As Integer
    For i = 0 To UBound(invalidSymbols)
        Dim invalidSymb As String
        invalidSymb = CStr(invalidSymbols(i))
        res = Replace(res, invalidSymb, REPLACE_SYMB)
    Next
    ReplaceInvalidPathSymbols = drive + res
End Function
The link to the page with the code:
No time to go further in the macro but it can be a good base, to test to see if the parts are not duplicated and if the names are suitable.
Then you have to open these parts and export them as a step. Unless it's possible by replacing this line with a step export.
See on this line:
Otherwise there is this utility (paid) that does the job obviously, so it must be feasible by macro (without necessarily making it so complicated).
Finally I freed up some time!
Here is the Codestack code modified with the addition of the export step and the removal of the sldprt part.
It remains to be seen if the name of the step file is correct or not.
If necessary, a test part of your supply may be necessary. (With an example of a name you want.)
Sub main()
    End If
    Dim i As Integer
            Dim errs As Long
            Dim warns As Long
                'Ajout sbadenis
                Set swModel = swApp.ActiveDoc 'on récupère le modèle actif
                swModel.Extension.SaveAs Left(swModel.GetPathName, InStrRev(swModel.GetPathName, ".")) & "STEP", 0, 0, Nothing, 0, 0 'export du fichier sldprt en step
                'Fin d'ajout sbadenis
                'Ajout sbadenis
                Kill outFilePath 'supprime le fichier sldprt
            Else
            End If
        Else
        End If
    Next
End Sub
    isInit = False
    Dim i As Integer
            If Not isInit Then
                ReDim swBodies(0)
                isInit = True
            Else
                End If
            End If
        End If
    Next
    If isInit Then
    Else
    End If
End Function
            Set swBody = selObj
            Set swFace = selObj
            Set swEdge = selObj
        End If
    End If
End Function
    Dim i As Integer
            Contains = True
            Exit Function
        End If
    Next
    Contains = False
End Function
    If outDir = "" Then
        If outDir = "" Then
        End If
    End If
    End If
End Function
    Dim res As String
    Dim drive As String
    Dim i As Integer
    Next
End Function
Fine, the names given to the files are the names of the functions in the tree, i.e. the body, so you just have to name the function in this sense.
You can save the multi bodies part as assembly (with option to have unique bodies only), and then save that assembly as STEP (with the option to export each part as induvial STEP). And this can eb done via a macro.
Hello
The possibility of recording only single bodies interests me!
How do you do it?
Sorry for a late reply, there was some issue with my login I guess.
When you use save bodies in the part file, and select the option to make an assembly, you would see another option to use unique bodies only. Select that option, and SW will export only one body.
