Hello,
We use a macro to save a drawing in pdf and dxf, I can't modify it so that it saves 2 sheets (or more)
in a single pdf
file if someone can guide me, thank you in advance
Dim swApp As Object
Dim swCustProp As CustomPropertyManager
Dim swSheet As SldWorks.Sheet
Dim vSheets As Variant
Dim i As Integer
Dim valOut1 As String
Dim valOut2 As String
Dim resolvedValOut1 As String
Dim resolvedValOut2 As String
Dim objShell As Shell
Dim Folder As Object
Dim objFolder As Folder
Dim objFile As Object
Dim Path As String
Dim nomb1 As String
Dim nomb2 As String
Dim nomb3 As String
Dim lettre As String
Dim Path1 As String
Dim Path2 As String
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swExportPDFData As SldWorks.ExportPdfData
Dim nFileName As String
Dim boolstatus As Boolean
Dim lErrors As Long
Dim lWarnings As Long
Sub main()
Set swModel = swApp.ActiveDoc
Set Part = swApp.ActiveDoc
Set objShell = New Shell
swPathName = Part.GetPathName
nomb1 = Len(swPathName)
nomb2 = InStrRev(swPathName, "\")
nomb3 = nomb1 - nomb2
swPath1 = Right(swPathName, nomb3)
nomb = nomb3 - 7
swPath2 = Left(swPath1, nomb)
lettre = Left(swPath2, 1)
swPath = Left(swPathName, InStrRev(swPathName, "\" & lettre, , 0))
' Pour savoir si le document est un plan
If swModel.GetType = swDocDRAWING Then
' Pour récupérer les propriétés Solidworks
Set swCustProp = swModel.Extension.CustomPropertyManager("")
swCustProp.Get2 "REFERENCE PIECE", valOut1, resolvedValOut1
swCustProp.Get2 "Révision", valOut2, resolvedValOut2
' Pour activer chaque feuille tour Ă tour
vSheets = swModel.GetSheetNames
For i = 1 To swModel.GetSheetCount
swModel.ActivateSheet vSheets(i - 1)
Set swSheet = swModel.GetCurrentSheet
' Pour enregistrer la feuille en DXF
Set swExportPDFData = swApp.GetExportFileData(1)
swExportPDFData.ViewPdfAfterSaving = False
nFileName = swPath & "mises_en_plan\" & resolvedValOut1 & "-" & resolvedValOut2 & ".DXF"
boolstatus = swExportPDFData.SetSheets(swExportData_ExportSpecifiedSheets, swSheet.GetName)
boolstatus = swModelDocExt.SaveAs(nFileName, 0, 0, swExportPDFData, lErrors, lWarnings)
' Pour enregistrer la feuille en PDF
swExportPDFData.ViewPdfAfterSaving = True
nFileName = swPath & "mises_en_plan\" & resolvedValOut1 & "-" & resolvedValOut2 & ".PDF"
Next i
Else: swApp.SendMsgToUser ("Cette macro fonctionne uniquement avec une mise en plan")
End If
Cyril_f
October 23, 2020, 12:37pm
2
Hello
You have to modify in the following line:
It is this line that only exports the active sheet, so you need to have different criteria in the macro to select the right action (all the sheets, a few...)
Thank you for your answer Cyril, I want to export all the sheets, I tried by deleting the For i loop, but it doesn't work anymore.
I'm not a macro expert!
Hello fifounet44 ,
This should do what you want:
Dim swApp As Object
Dim i As Integer
Dim Path As String
Dim nomb1 As String
Dim nomb2 As String
Dim nomb3 As String
Dim Path1 As String
Dim Path2 As String
Dim lErrors As Long
Sub main()
nomb = nomb3 - 7
boolstatus = swExportPDFData.SetSheets(swExportData_ExportSpecifiedSheets, vSheets)
End If
Kind regards
Good evening
The code of d.roger or this one:
boolstatus = swExportPDFData.SetSheets(swExportData_ExportAllSheets, "")
Good evening d.roger, Thank you, I'll try on Monday morning, thank you Cyril too! Have a good weekend
Hello I just tried it and it works fine. When I see the code it seemed simple, everything is easier when you master it! Thank you again.
