Macro export DXF to new folder
Hello,
I have a macro to export my DRAWING file to several DXF files with separate sheets (one file per sheet). Files are saved in the root folder of the drawing.
I would like to know if there is a command to create a new folder (if possible by choosing the name) in which to save all DXF sheets at the time of export?
If we can create a compressed folder I also take.
Thank you very much
Manu
Hello,
Everything is doable.
For my part, I use this code to navigate in Windows Explorer:
Private Declare PtrSafe Function SHBrowseForFolder Lib "shell32.dll" _
Alias "SHBrowseForFolderA" (lpBrowseInfo As BrowseInfo) As Long
Private Declare PtrSafe Function SHGetPathFromIDList Lib "shell32.dll" _
(ByVal pidList As LongPtr, ByVal lpBuffer As String) As Long
Public Declare PtrSafe Function SendMessageA Lib "user32" _
(ByVal hWnd As LongPtr, ByVal wMsg As Long, _
ByVal wParam As LongPtr, lParam As Any) As LongPtr
Private Declare PtrSafe Sub CoTaskMemFree Lib "ole32.dll" (ByVal hMem As LongPtr)
Private Const BIF_RETURNONLYFSDIRS As Long = 1
Private Const CSIDL_DRIVES As Long = &H11
Private Const WM_USER As Long = &H400
Private Const MAX_PATH As Long = 260
'// message from browser
Private Const BFFM_INITIALIZED As Long = 1
Private Const BFFM_SELCHANGED As Long = 2
Private Const BFFM_VALIDATEFAILEDA As Long = 3 '// lParam:szPath ret:1(cont),0(EndDialog)
Private Const BFFM_VALIDATEFAILEDW As Long = 4 '// lParam:wzPath ret:1(cont),0(EndDialog)
Private Const BFFM_IUNKNOWN As Long = 5 '// provides IUnknown to client. lParam: IUnknown*
'// messages to browser
Private Const BFFM_SETSTATUSTEXTA As Long = WM_USER + 100
Private Const BFFM_ENABLEOK As Long = WM_USER + 101
Private Const BFFM_SETSELECTIONA As Long = WM_USER + 102
Private Const BFFM_SETSELECTIONW As Long = WM_USER + 103
Private Const BFFM_SETSTATUSTEXTW As Long = WM_USER + 104
Private Const BFFM_SETOKTEXT As Long = WM_USER + 105 '// Unicode only
Private Const BFFM_SETEXPANDED As Long = WM_USER + 106 '// Unicode only
Public Type BrowseInfo
hWndOwner As LongPtr
pIDLRoot As LongPtr
pszDisplayName As String
lpszTitle As String
ulFlags As Long
lpfnCallback As LongPtr
lParam As LongPtr
iImage As Long
End Type
'====== Folder Browser for 64 bit VBA 7 ========
Public Function FolderBrowse(ByVal sDialogTitle As String, ByVal sInitFolder As String) As String
Dim ReturnPath As String
Dim b(MAX_PATH) As Byte
Dim pItem As Long
Dim sFullPath As String
Dim bi As BrowseInfo
Dim ppidl As Long
sInitFolder = CorrectPath(sInitFolder)
' Note VBA windows and dialogs do not have an hWnd property.
bi.hWndOwner = 0 'Windows Main Screen handle.
' SHGetSpecialFolderLocation bi.hWndOwner, CSIDL_DRIVES, ppidl
bi.pIDLRoot = 0 'ppidl
bi.pszDisplayName = VarPtr(b(0))
bi.lpszTitle = sDialogTitle
bi.ulFlags = BIF_RETURNONLYFSDIRS
If FolderExists(sInitFolder) Then bi.lpfnCallback = PtrToFunction(AddressOf BFFCallback)
bi.lParam = StrPtr(sInitFolder)
pItem = SHBrowseForFolder(bi)
If pItem Then ' Succeeded
sFullPath = Space$(MAX_PATH)
If SHGetPathFromIDList(pItem, sFullPath) Then
ReturnPath = left$(sFullPath, InStr(sFullPath, vbNullChar) - 1) ' Strip nulls
CoTaskMemFree pItem
End If
End If
If ReturnPath <> "" Then
If right$(ReturnPath, 1) <> "\" Then
ReturnPath = ReturnPath & "\"
End If
End If
FolderBrowse = ReturnPath
End Function
' typedef int (CALLBACK* BFFCALLBACK)(HWND hwnd, UINT uMsg, LPARAM lParam, LPARAM lpData);
Private Function BFFCallback(ByVal hWnd As LongPtr, ByVal uMsg As LongPtr, ByVal lParam As LongPtr, ByVal sData As String) As LongPtr
If uMsg = BFFM_INITIALIZED Then
SendMessageA hWnd, BFFM_SETSELECTIONA, True, ByVal sData
End If
End Function
Private Function PtrToFunction(ByVal lFcnPtr As LongPtr) As LongPtr
PtrToFunction = lFcnPtr
End Function
Private Function CorrectPath(ByVal sPath As String) As String
If right$(sPath, 1) = "\" Then
If Len(sPath) > 3 Then sPath = left$(sPath, Len(sPath) - 1) ' Strip backslash from non-root
Else
If Len(sPath) = 2 Then sPath = sPath & "\" ' Append backslash to root
End If
CorrectPath = sPath
End Function
Public Function FolderExists(ByVal sFolderName As String) As Boolean
Dim att As Long
On Error Resume Next
att = GetAttr(sFolderName)
If Err.Number = 0 Then
FolderExists = True
Else
Err.Clear
FolderExists = False
End If
On Error GoTo 0
End Function
Called in the main code by:
Dim sDossDest As String
sDossDest = FolderBrowse("Choisir un répertoire à traiter...", "C:\Export") 'A la place de C:\Export mettre ce qui convient ou ne rien mettre pour arriver à la racine
Then you have to reuse the sDossDest variable to format the record path.
For the ZIp, same I use the function below:
Public Sub ZipRep() 'Fonction reprise du site http://vb.developpez.com/faqvbs/?page=II.2.3#fsoCompresDir
Const ForReading = 1, ForWriting = 2, ForAppending = 8
Dim Source, Destination, MyHex, MyBinary, i
Dim oShell, oApp, oFolder, oCTF, oFile
Dim oFileSys
Source = Rep 'Variable récupérant le nom de dossier à compresser
Destination = "C:\Export\" & NameRep & ".zip" 'Nom final du fichier compressé
MyHex = _
Array(80, 75, 5, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0)
For i = 0 To UBound(MyHex)
    MyBinary = MyBinary & Chr(MyHex(i))
Next
Set oShell = CreateObject("WScript.Shell")
Set oFileSys = CreateObject("Scripting.FileSystemObject")
'Creation du zip
Set oCTF = oFileSys.CreateTextFile(Destination, True)
oCTF.Write MyBinary
oCTF.Close
Set oCTF = Nothing
Set oApp = CreateObject("Shell.Application")
Set oFolder = oApp.NameSpace(Source)
If Not oFolder Is Nothing Then _
    oApp.NameSpace(Destination).CopyHere oFolder.Items
Set oFile = Nothing
'Search for a Compressing dialog
    Do While oShell.AppActivate("Compressing...") = False
        If oFolder.Items.Count > i Then
            'There's a file in the zip file now, but
            'compressing may not be done just yet
            Exit Do
        End If
        If l > 30 Then
            '3 seconds has elapsed and no Compressing dialog
            'The zip may have completed too quickly so exiting
            Exit Do
        End If
        DoEvents
        Sleep 100
        l = l + 1
    Loop
    ' Wait for compression to complete before exiting
    Do While oShell.AppActivate("Compressing...") = True
        DoEvents
        Sleep 100
    Loop
End Sub
Also to be called in another procedure of the module by a simple ZipRep Call.
The two codes are to be adapted according to the initial macro (reuse of the different variables)
Wow ok, I just thought I had to add a little line of code :sweat_smile:
Thank you for your feedback in any case. I'll try to look into it to see if I can get something out but I'm far from being an expert in MACRO.
If necessary I can do the full macro, just provide me with the base code
It's so great your proposal.
Below:
' Préconditions:
'       (1) Document de mise en plan ouvert.
'       (2) La mise en plan contient au moins une feuille.
' Postconditions:
'       (1) Un fichier DXF est généré pour chaque feuille,
'           remplace tout fichier existant
'       (2) Les noms des fichiers DXF sont basés sur le nom de la feuille, par exemple Feuille1
'           est enregistrée sous Feuille1.dxf, Feuille2 est enregistré sous Feuille2.dxf, et ainsi de suite
Option Explicit
Public Enum swSaveAsVersion_e
    swSaveAsCurrentVersion = 0  '  default
    swSaveAsFormatProE = 2      '  Enregistre la pièce SolidWorks au format Pro/E.prt/.asm extension (pas comme SolidWorks.prt/.asm)
End Enum
Public Enum swSaveAsOptions_e
    swSaveAsOptions_Silent = &H1            '  Enregistrer le document en mode silencieux ou non
    swSaveAsOptions_Copy = &H2              '  Enregistrer le document en tant que copie ou non
    swSaveAsOptions_SaveReferenced = &H4    '  Enregistrer ou non les documents référencés (dessins et pièces uniquement)
End Enum
Public Enum swFileSaveError_e
    swGenericSaveError = &H1
    swReadOnlySaveError = &H2
    swFileNameEmpty = &H4                       '  Le nom du fichier ne peut pas être vide.
    swFileNameContainsAtSign = &H8              '  Le nom du fichier ne peut pas contenir le caractère arobase (@).
    swFileLockError = &H10
    swFileSaveFormatNotAvailable = &H20         '  Le type de fichier « Enregistrer sous » n'est pas valide.
    swFileSaveAsDoNotOverwrite = &H80           '  L'utilisateur a choisi de ne pas écraser un fichier existant
    swFileSaveAsInvalidFileExtension = &H100    '  L'extension du fichier diffère du type de document SolidWorks.
End Enum
Public Enum swFileSaveWarning_e
    swFileSaveWarning_RebuildError = &H1    '  Le fichier a été enregistré avec une erreur de reconstruction.
End Enum
Public Enum swDxfFormat_e
    swDxfFormat_R12 = 0
    swDxfFormat_R13 = 1
    swDxfFormat_R14 = 2
    swDxfFormat_R2000 = 3
End Enum
Public Enum swArrowDirection_e
    swINSIDE = 0
    swOUTSIDE = 1
    swSMART = 2
End Enum
Public Enum swUserPreferenceToggle_e
    swDxfMapping = 8
    swDXFDontShowMap = 21
End Enum
Public Enum swUserPreferenceIntegerValue_e
    swDxfVersion = 0
    swDxfOutputFonts = 1
    swDxfMappingFileIndex = 2
    swDxfOutputLineStyles = 135
    swDxfOutputNoScale = 136
End Enum
Public Enum swUserPreferenceDoubleValue_e
    swDxfOutputScaleFactor = 79
End Enum
Public Enum swUserPreferenceStringListValue_e
    swDxfMappingFiles = 0
End Enum
Sub main()
    Dim swApp                       As SldWorks.SldWorks
    Dim swModel                     As SldWorks.ModelDoc2
    Dim swDraw                      As SldWorks.DrawingDoc
    Dim swCustProp                  As CustomPropertyManager
    Dim vSheetName                  As Variant
    Dim nErrors                     As Long
    Dim nWarnings                   As Long
    Dim nRetval                     As Long
    Dim sPathname                   As String
    Dim resolvedRevision            As String
    Dim Revision                    As String
    Dim dateNow                     As String
    Dim bShowMap                    As Boolean
    Dim nNumSheet                   As Long
    Dim i                           As Long
    Dim bRet                        As Boolean
    Set swModel = swApp.ActiveDoc
    Set swDraw = swModel
    ' Paramètres actuels
    Debug.Print "DxfMapping             = " & swApp.GetUserPreferenceToggle(swDxfMapping)
    Debug.Print "DXFDontShowMap         = " & swApp.GetUserPreferenceToggle(swDXFDontShowMap)
    Debug.Print "DxfVersion             = " & swApp.GetUserPreferenceIntegerValue(swDxfVersion)
    Debug.Print "DxfOutputFonts         = " & swApp.GetUserPreferenceIntegerValue(swDxfOutputFonts)
    Debug.Print "DxfMappingFileIndex    = " & swApp.GetUserPreferenceIntegerValue(swDxfMappingFileIndex)
    Debug.Print "DxfOutputLineStyles    = " & swApp.GetUserPreferenceIntegerValue(swDxfOutputLineStyles)
    Debug.Print "DxfOutputNoScale       = " & swApp.GetUserPreferenceIntegerValue(swDxfOutputNoScale)
    Debug.Print "DxfOutputScaleFactor   = " & swApp.GetUserPreferenceDoubleValue(swDxfOutputScaleFactor)
    Debug.Print "DxfMappingFiles        = " & swApp.GetUserPreferenceStringListValue(swDxfMappingFiles)
    Debug.Print ""
    ' Désactiver l'affichage de la carte
    swApp.SetUserPreferenceToggle swDXFDontShowMap, True
    ' On récupère la date du jour et on la met dans un format pouvant se mettre dans le nom d'un fichier
    dateNow = Replace(Date, "/", ".")
    ' On récupère les valeurs qui nous intéresse dans les propriétés personnalisées du plan
    swCustProp.Get2 "Révision", Revision, resolvedRevision          'Récupère la donnée Révision du fichier Mise en Plan
    ' On récupère le nom du fichier de la mise en plan
    sPathname = Replace(swDraw.GetPathName, ".SLDDRW", "")
    ' On récupère le nom des feuilles
    vSheetName = swDraw.GetSheetNames
    For i = 0 To UBound(vSheetName)
        bRet = swDraw.ActivateSheet(vSheetName(i))
        bRet = swModel.SaveAs4(sPathname & " - " & resolvedRevision & " - " & i + 1 & "_" & vSheetName(i) & " - " & dateNow & ".dxf", swSaveAsCurrentVersion, swSaveAsOptions_Silent, nErrors, nWarnings)
        Debug.Assert bRet
    Next i
    ' Retour à la Feuille 1
    bRet = swDraw.ActivateSheet(vSheetName(0))
    ' Remise en place du paramétrage initial
    swApp.SetUserPreferenceToggle swDXFDontShowMap, bShowMap
End Sub
There are certainly some superfluous things...
And I would like my DXF files to be saved in a compressed folder named:
DESIGNATION - INDEX - CURRENT DATE - DXF
So get the variables:
sPathname & " - " & resolvedRevision & " - " & dateNow & " - DXF"
After that, if the folder is simply called " DXF ", that's fine with me too.
Thank you very much for your help!!
I think BATCHCONVERTER from MyCAD tools should suit you
Unfortunately, my company does not want to take on an additional license...
Hello,
I don't know if it can help you but here's what I did a while ago with AI.
The goal is to save all the MEPs in PDF of the assemblies and sub-assemblies in a folder.
Option Explicit
' --- DÉCLARATIONS GLOBALES ---
Dim swApp As Object
Dim swModel As Object
Dim fs As Object
Dim exportPath As String
Dim xlApp As Object
Dim xlWB As Object
Dim xlSheet As Object
Dim rowCount As Integer
' --- CONSTANTES ---
Const swDocASSEMBLY As Long = 2
Const swDocDRAWING As Long = 3
Const swPDFExportShowPDF As Long = 188
Const swMultiSheetPdf As Long = 187
Const swSaveAsOptions_Silent As Long = 1
Const swOpenDocOptions_Silent As Long = 1
Sub main()
    If swModel Is Nothing Then MsgBox "Ouvrez un assemblage.": Exit Sub
    If swModel.GetType <> swDocASSEMBLY Then MsgBox "Le document doit être un assemblage.": Exit Sub
    Set fs = CreateObject("Scripting.FileSystemObject")
    Set xlApp = CreateObject("Excel.Application")
    ' Paramètres PDF
    swApp.SetUserPreferenceToggle swPDFExportShowPDF, False
    swApp.SetUserPreferenceIntegerValue swMultiSheetPdf, 1
    ' Dossier d'export
    Dim fullPath As String: fullPath = swModel.GetPathName
    Dim folderPath As String: folderPath = Left(fullPath, InStrRev(fullPath, "\"))
    Dim assemblyName As String: assemblyName = GetCleanName(fullPath)
    exportPath = folderPath & "EXPORT_PDF - " & assemblyName & "\"
    If Not fs.FolderExists(exportPath) Then fs.CreateFolder exportPath
    ' Init Excel
    Set xlWB = xlApp.Workbooks.Add
    Set xlSheet = xlWB.Sheets(1)
    xlSheet.Cells(1, 1) = "Ordre"
    xlSheet.Cells(1, 2) = "Nom du Fichier"
    xlSheet.Cells(1, 3) = "Statut"
    rowCount = 2
    ' --- TRAITEMENT ---
    ' 1. Traiter l'assemblage de tête avec l'indice "01"
    TraiterComposant swModel, "01"
    ' 2. Parcourir l'arbre (Ordre visuel via Features)
    TraverserArbreParFeatures swModel, "01"
    ' Finalisation
    xlSheet.Columns.AutoFit
    xlWB.SaveAs exportPath & "Rapport_Export.xlsx"
    xlApp.Visible = True
    MsgBox "Export terminé avec succès (Format 01) !"
End Sub
Sub TraverserArbreParFeatures(parentModel As Object, parentIndex As String)
    Dim swFeat As Object
    Dim swComp As Object
    Dim swCompModel As Object
    Dim childIndex As String
    Dim exportCounter As Integer
    Dim localProcessed As Object
    ' Variable pour vérifier l'exclusion de nomenclature
    Dim swChildConf As Object
    Set localProcessed = CreateObject("Scripting.Dictionary")
    exportCounter = 1
    Set swFeat = parentModel.FirstFeature
        If swFeat.GetTypeName2 = "Reference" Or swFeat.GetTypeName2 = "ContextComponent" Then
            Set swComp = swFeat.GetSpecificFeature2
            If Not swComp Is Nothing Then
                ' 1. Vérifier si le composant n'est pas supprimé ET n'est pas exclu de la nomenclature
                ' swComponentExcludeFromBOM = 128 (optionnel si on veut utiliser la constante)
                If swComp.GetSuppression <> 0 And swComp.ExcludeFromBOM = False Then
                    Set swCompModel = swComp.GetModelDoc2
                    If Not swCompModel Is Nothing Then
                        Dim fileName As String: fileName = GetCleanName(swCompModel.GetPathName)
                        ' FILTRE : Assemblage + "-M-A-"
                        If swCompModel.GetType = swDocASSEMBLY And InStr(1, fileName, "-M-A-", vbTextCompare) > 0 Then
                            ' Unicité par niveau
                            If Not localProcessed.Exists(fileName) Then
                                localProcessed.Add fileName, True
                                childIndex = parentIndex & "." & Format(exportCounter, "00")
                                If TraiterComposant(swCompModel, childIndex) Then
                                    exportCounter = exportCounter + 1
                                    ' Récursivité
                                    TraverserArbreParFeatures swCompModel, childIndex
                                End If
                            End If
                        End If
                    End If
                End If
            End If
        End If
    Loop
End Sub
Function TraiterComposant(model As Object, index As String) As Boolean
    Dim filePath As String: filePath = model.GetPathName
    Dim fileName As String: fileName = GetCleanName(filePath)
    Dim drwPath As String: drwPath = Left(filePath, InStrRev(filePath, ".")) & "slddrw"
    ' Écriture Excel (le ' force le format Texte)
    xlSheet.Cells(rowCount, 1) = "'" & index
    xlSheet.Cells(rowCount, 2) = fileName
    If fs.FileExists(drwPath) Then
        ' Export avec le préfixe formaté
        ExportToPDF drwPath, exportPath & index & " - " & fileName & ".pdf"
        xlSheet.Cells(rowCount, 3) = "OK"
    Else
        xlSheet.Cells(rowCount, 3) = "Plan manquant"
    End If
    rowCount = rowCount + 1
    TraiterComposant = True
End Function
Sub ExportToPDF(drwPath As String, pdfPath As String)
    Dim swDraw As Object
    Dim errors As Long
    Dim warnings As Long
    Set swDraw = swApp.OpenDoc6(drwPath, swDocDRAWING, swOpenDocOptions_Silent, "", errors, warnings)
    If Not swDraw Is Nothing Then
        swDraw.Extension.SaveAs2 pdfPath, 0, swSaveAsOptions_Silent, Nothing, "", False, errors, warnings
        swApp.CloseDoc swDraw.GetTitle
    End If
End Sub
Function GetCleanName(fullPath As String) As String
    Dim n As String
    n = Mid(fullPath, InStrRev(fullPath, "\") + 1)
    If InStrRev(n, ".") > 0 Then n = Left(n, InStrRev(n, ".") - 1)
    GetCleanName = n
End Function
Hello,
Attached is the code:
' Préconditions:
' Postconditions:
Option Explicit
End Enum
End Enum
End Enum
End Enum
    swDxfFormat_R12 = 0
    swDxfFormat_R13 = 1
    swDxfFormat_R14 = 2
End Enum
    swINSIDE = 0
    swOUTSIDE = 1
    swSMART = 2
End Enum
    swDxfMapping = 8
End Enum
    swDxfVersion = 0
End Enum
End Enum
End Enum
Dim nErrors                     As Long
Dim nRetval                     As Long
Dim i                           As Long
Dim l                           As Long
Dim bRet                        As Boolean
Dim Rep                         As String
Dim fs                          As Scripting.FileSystemObject
Declare PtrSafe Sub Sleep Lib "kernel32" (ByVal dwMilliseconds As Long)
Sub main()
    Debug.Print ""
    'On récupère le chemin d'accès de la mise en plan
    sPathname = swDraw.GetPathName
    sPathname = Left(sPathname, InStrRev(sPathname, "\"))
    sDossDest = GetFolder("Sélectionner le dossier d'enregistrement...") & "\"
    Debug.Print sDossDest
    sPathname = Mid(sPathname, InStrRev(sPathname, "\") + 1) 'Purge le chemin d'accès
    sPathname = Replace(sPathname, ".SLDDRW", "")
    sDossDest = sDossDest & sPathname & "-" & resolvedRevision & "-" & dateNow & "-DXF" & "\"
    Call TestRep
        bRet = swModel.SaveAs4(sDossDest & sPathname & " - " & resolvedRevision & " - " & i + 1 & "_" & vSheetName(i) & " - " & dateNow & ".dxf", swSaveAsCurrentVersion, swSaveAsOptions_Silent, nErrors, nWarnings)
        Debug.Assert bRet
    Next i
    Call ZipRep
End Sub
Sub TestRep()
Set fs = New Scripting.FileSystemObject
    ' test si le repertoire existe
        If Not fs.FolderExists(sDossDest) Then
         '  création du repertoire si besoin
            fs.CreateFolder (sDossDest)
         End If
    Set fs = Nothing
End Sub
Dim oFileSys
Source = sDossDest
Destination = Left(sDossDest, Len(sDossDest) - 1) & ".zip"
MyHex = _
Next
'Creation du zip
oCTF.Write MyBinary
oCTF.Close
Set oCTF = Nothing
Set oFolder = oApp.Namespace(Source)
    oApp.Namespace(Destination).CopyHere oFolder.Items
Set oFile = Nothing
            Exit Do
        End If
        If l > 30 Then
            Exit Do
        End If
        DoEvents
        Sleep 100
        l = l + 1
    Loop
        DoEvents
        Sleep 100
    Loop
    fs.DeleteFolder Left(sDossDest, Len(sDossDest) - 1), True
End Sub
Function GetFolder(Title As String)
    Dim folder As FileDialog
    Dim selected_folder As String
    Set folder = Excel.Application.FileDialog(msoFileDialogFolderPicker)
    With folder
        .AllowMultiSelect = False
        .ButtonName = "Ok"
        .Filters.Clear
        .InitialFileName = sPathname
        .Title = Title
        If .Show <> -1 Then GoTo NextCode
        selected_folder = .SelectedItems(1)
    End With
NextCode:
    Debug.Print selected_folder
    GetFolder = selected_folder
    Set folder = Nothing
End Function
You need to activate the libraries below:
And just for the record, with regard to my first answer, the Windows explorer code I was using until now no longer seems to be compatible with Windows 11 25H2 (random crash of the macro and SW by side effect).
Hello,
Perfect thank you, I'm finishing the drawing I'm working on and I'm testing it right after.
Hello,
So I was able to test on my own.
First of all, I can't find the reference "Microsoft Forms 2.0 Object Library", perhaps which explains the rest of my message.
Because secondly, the Macro crashes as soon as I execute it with the message " Runtime error ' 5 ': Incorrect argument or procedure call"
A priori, it is this line that is the cause
BUT
When I run the macro in step-by-step debug mode, it works perfectly fine.
Hello,
Trying to put this:
VBA.Left(sDossDest, Len(sDossDest) - 1) & ".zip"
Sometimes the Left and Right functions are problematic.
By the way, I'm in the process of reusing the zip creation code on my side on my macros because Microsoft Scripting Runtime is doomed to disappear
Now it's a bug on this line:
But in step mode it still works great.
Hello,
To try with this new code (removal of references to Microsoft Scripting Runtime).
' Préconditions:
' Postconditions:
Option Explicit
End Enum
End Enum
End Enum
End Enum
    swDxfFormat_R12 = 0
    swDxfFormat_R13 = 1
    swDxfFormat_R14 = 2
End Enum
    swINSIDE = 0
    swOUTSIDE = 1
    swSMART = 2
End Enum
    swDxfMapping = 8
End Enum
    swDxfVersion = 0
End Enum
End Enum
End Enum
Dim nErrors                     As Long
Dim nRetval                     As Long
Dim i                           As Long
Dim l                           As Long
Dim bRet                        As Boolean
Dim Rep                         As String
Dim fileNum                     As Integer
Sub main()
    Debug.Print ""
    Call TestRep
        Debug.Assert bRet
    Next i
    Call ZipRep
End Sub
Sub TestRep()
        If Dir(sDossDest, vbDirectory) = "" Then
            MkDir (sDossDest)
         End If
End Sub
Sub ZipRep()
Dim Source As String
Dim Destination As String
Dim oApp, oFolder
Source = VBA.Left(sDossDest, Len(sDossDest) - 1)
Destination = VBA.Left(sDossDest, Len(sDossDest) - 1) & ".zip"
If Dir(Destination) = "" Then
    Open Destination For Output As #1
    Print #1, "PK" & Chr(5) & Chr(6) & String(18, vbNullChar)
    Close #1
End If
Set oFolder = oApp.Namespace(Source & "\")
    oApp.Namespace(Destination & "\").CopyHere oFolder.Items
WaitForZipToFinish (Destination)
Kill (Source & "\*.*")
RmDir (Source)
End Sub
    With folder
        .ButtonName = "Ok"
        .Filters.Clear
        .Title = Title
    End With
NextCode:
End Function
Sub WaitForZipToFinish(zipPath As String)
    Dim lastSize As Long
    Dim newSize As Long
    Dim stableCount As Integer
    lastSize = FileLen(zipPath)
    stableCount = 0
    Do
        DoEvents
        Sleep 100
        newSize = FileLen(zipPath)
        If newSize = lastSize Then
            stableCount = stableCount + 1
        Else
            stableCount = 0
        End If
        lastSize = newSize
        ' ZIP is stable for 3 seconds = done
        If stableCount >= 3 Then Exit Do
    Loop
End Sub
No, not better sorry...
It remains completely frozen without even an error message.
For the moment I run the Macro with the debugger, it works well with the first code provided.
Which version of SW, Office and Windows?
Works perfectly at home on Sw2025, Office 365 and Windows 11 25H2
Hello,
SW2025, Windows 11 for office I don't have any active license... Which could explain this.
