Anyone would know how to create a macro to open the DXF in 3D curve and put the unit in millimeters without going through the dialog box?
Thank you.
Thank you.
Hello
VBA programming is not a problem?
See these links which give good leads:
http://help.solidworks.com/2013/english/api/sldworksapi/Import_DXF_File_into_Part_Sketch_Example_VB.htm
http://help.solidworks.com/2014/english/api/sldworksapi%5Cimport_dxf_dwg_file_example_vb.htm
I'm able to do it, but it takes time and learning VBA programming is always beneficial and not very complicated.
To start, we can record a macro when importing a DXF3D into SolidWorks, and then see what the code is:
http://help.solidworks.com/2013/french/SolidWorks/sldworks/c_recording_playing_macros.htm
Precisely I tested but the import of the DXF the dialog box does not open when I restart the macro and therefore the DXF opens on a drawing...
I also think that the problem may be that your file is a document that includes 4
so SW may not understand since there is no constraint relationship between these parts
they are independent
and you are looking to create solids?
#. JL:
I want to choose the "3D curve or model" option when I launch the macro in order to recreate the model in 3D.
see PJ
#GT22:
how to explain that SOLIDWORKS generates the 4 parts when you do it manually?
There must be a particular configuration I think.
That's precisely where the problem is
and I don't have an answer but the fact is
if we save your edrawing so the link in an X file
impossible to open it in Solidworks without conflict
at least that's what I saw and that's what it resulted despite X tests on SW 2012 premium
maybe you need to convert your DXF 3D file
preferably parasolid or IGES, STEP
Is your goal to find all the X Y Z numerical coordinates of the room?
so for me already it is necessary that each part file be independent
This is a first step
After saving each piece independently and naming them in a clean file
well me say that
http://help.solidworks.com/2012/English/api/swconst/SolidWorks.Interop.swconst~SolidWorks.Interop.swconst.swImportDxfDwg_ImportMethod_e.html
