Isolate macro based on a configuration property
Hello
I'd like to make a macro to isolate in an assembly (by going through the whole tree) only the parts that contain the custom property in a " REF-PIECE " part and that it is different from empty.
Is it possible? And do you have any idea how to do that?
chatGPT generated this code for me, it works. But I find it slow, you have to.
20sec for an assembly that doesn't have too many parts though. Do you see something in the code that could be optimized to go much faster?
Option Explicit
Const swDocPART = 1
Const swDocASSEMBLY = 2
Const swDocDRAWING = 3
Dim swAssy As SldWorks.AssemblyDoc
Dim componentsToSelect As Collection
Dim processedComponents As Object ' Dictionnaire pour suivre les composants traités
Sub main()
    Set swModel = swApp.ActiveDoc
    If swModel Is Nothing Then
        MsgBox "Aucun document actif."
        Exit Sub
    End If
    If swModel.GetType <> swDocASSEMBLY Then
        MsgBox "Ce script fonctionne uniquement dans un assemblage."
        Exit Sub
    End If
    Set swAssy = swModel
    Set componentsToSelect = New Collection
    Set processedComponents = CreateObject("Scripting.Dictionary") ' Utilisation d'un dictionnaire pour une recherche rapide
    ' Récupère le composant racine
    Dim rootComp As SldWorks.Component2
    Set rootComp = swModel.ConfigurationManager.ActiveConfiguration.GetRootComponent3(True)
    If rootComp Is Nothing Then
        MsgBox "Composant racine introuvable."
        Exit Sub
    End If
    ' Appel du parcours
    Call ParcourirComposants(rootComp)
    ' Sélection des pièces avec REF-PIECE non vide
    swModel.ClearSelection2 True
    Dim comp As SldWorks.Component2
    ' Création de la sélection multiple
    For Each comp In componentsToSelect
        comp.Select4 True, Nothing, False
    Next comp
    ' Si des pièces ont été sélectionnées, on les isole
    If componentsToSelect.Count > 0 Then
        swApp.SendMsgToUser2 "Isoler les pièces trouvées.", swMessageBoxIcon_e.swMbInformation, swMessageBoxBtn_e.swMbOk
        ' Isoler avec SendKeys
        SendKeys "i"
    Else
        MsgBox "Aucune pièce avec la propriété de configuration 'REF-PIECE' trouvée."
    End If
Sub ParcourirComposants(compParent As SldWorks.Component2)
    Dim vChildComp As Variant
    Dim swChild As SldWorks.Component2
    Dim i As Integer
    Dim swModelChild As ModelDoc2
    Dim swConf As SldWorks.Configuration
    Dim val As String
    Dim compKey As String
    Dim fileName As String
    Dim confName As String
    If compParent Is Nothing Then Exit Sub
    ' Récupérer les composants enfants
    vChildComp = compParent.GetChildren
    ' Vérification : Si des enfants existent
    If Not IsEmpty(vChildComp) Then
        ' On parcourt le tableau des enfants
        For i = 0 To UBound(vChildComp)
            Set swChild = vChildComp(i)
            If Not swChild.IsSuppressed Then
                If swChild.GetModelDoc2 Is Nothing Then
                    swChild.ReferencedConfiguration = swChild.ReferencedConfiguration ' Force le chargement
                End If
                Set swModelChild = swChild.GetModelDoc2
                ' Optimisation : Vérifie d'abord si le modèle est déjà chargé
                If Not swModelChild Is Nothing Then
                    ' Vérification que le type de modèle est une pièce
                    If swModelChild.GetType = swDocPART Then
                        confName = swChild.ReferencedConfiguration
                        Set swConf = swModelChild.GetConfigurationByName(confName)
                        If Not swConf Is Nothing Then
                            val = swConf.CustomPropertyManager.Get("REF-PIECE")
                            ' Si la propriété REF-PIECE n'est pas vide
                            If Len(Trim(val)) > 0 Then
                                fileName = GetFileNameFromPath(swChild.GetPathName) ' Extraire le nom du fichier
                                compKey = fileName & "-" & confName ' Créer la clé unique avec le nom de fichier et la configuration
                                ' Si la clé n'existe pas déjà dans le dictionnaire, on l'ajoute
                                If Not processedComponents.Exists(compKey) Then
                                    componentsToSelect.Add swChild
                                    processedComponents.Add compKey, True ' Ajoute la clé au dictionnaire
                                End If
                            End If
                        End If
                    End If
                End If
            End If
            ' Appel récursif sur les sous-enfants
            Call ParcourirComposants(swChild)
        Next i
    End If
' Fonction pour extraire le nom du fichier depuis le chemin
Function GetFileNameFromPath(filePath As String) As String
    fileName = Mid(filePath, InStrRev(filePath, "\") + 1)
    GetFileNameFromPath = fileName
End Function
Hello
What I would do is declare all the variables that are in the For loop before the loop (in other words, output all the lines with a Dim). They don't need to be redeclared at each iteration, as long as their value is reassigned in the loop.
I'm not saying that it will speed up much but it's better for the cpu.
Hello, thank you for your answer, I just made the change (I modified the code of my basic message accordingly). I didn't see any time saved unfortunately :confused:
If it's not of interest to you, you can comment on the recursive call on sub-children. With an apostrophe in front of Call.
            ' Call ParcourirComposants(swChild)
You can try with a With block, but I don't know if Solidworks handles it anymore
Sub main()
        Exit Sub
    End If
        Exit Sub
    End If
        Exit Sub
    End If
    ' Appel du parcours
    Next comp
        SendKeys "i"
    Else
    End If
    Dim i As Integer
    Dim val As String
            With swChild
                If Not .IsSuppressed Then
                    If .GetModelDoc2 Is Nothing Then
                        .ReferencedConfiguration = .ReferencedConfiguration ' Force le chargement
                    End If
                    Set swModelChild = .GetModelDoc2
                            confName = .ReferencedConfiguration
                                    fileName = GetFileNameFromPath(.GetPathName) ' Extraire le nom du fichier
                                    End If
                                End If
                            End If
                        End If
                    End If
                End If
            End With
        Next i
    End If
End Function
Note: Be careful, I have left recursion active on this code.
Alternatively, you can also put breakpoints (in the column to the left of the macro editor's row number) in key places to determine which portions of the code are the most time-consuming. Just to know what to work on.
In a 1st step, I would place a breakpoint in front of the line that follows the line of the beginning of the For loop (in other words, in front of the line Set swChild = vChildComp(i)). This will allow you, during the runtime, to know when the loop and each new iteration start, and thus to evaluate/measure how much time passes between 2 iterations.
The code seems to me to be well designed and rather well constituted and optimized. (For a cat that's pretty good, I have to admit!)
On an assembly of 2296 parts with 339 unique parts file time about 20s (without any parts with the REF-PIECE property specified.)
On an assembly with 152 parts for 142 single parts time 2-3 s max (without any parts with the property to be insulated)
This seems pretty correct to me given that it goes through all the sets and subsets.
On the other hand, be careful to launch your code only on resolved assemblies otherwise it may not isolate you from some unresolved components, if I'm not mistaken.
For the isolation part, you should avoid running shortcuts in a macro (don't execute anything if the shortcut on the workstation is not installed (or worse execute something else if the shortcut is used for something else!)
Replace:
        SendKeys "i"
By:
         Dim status As Boolean
        status = swModel.Isolate()
        swModel.SetIsolateVisibility (swIsolateVisibility_e.swIsolateVisibility_HIDDEN) 'swIsolateVisibility_HIDDEN  swIsolateVisibility_TRANSPARENT swIsolateVisibility_WIREFRAME
        'Exit isolate
        'status = swModel.ExitIsolate() 'Pour suppression éventuel de la fonction isolé (à déplacer ou rajouter du code entre isolé et suppression isolé)
Ability to choose something other than hidden from the isolated options (HIDDEN, TRANSPARENT or WIREFRAME)
Hello
Thank you for your answers.
To isolate it, it would be possible to display this window as when you manually isolate to exit it quickly, with the swModel.SetIsolateVisibility (swIsolateVisibility_e.swIsolateVisibility_HIDDEN)
I don't think you can display a button in the macro that launches the code to exit isolate:
See the attached macro with the addition of the button.
Isolate-Prop.swp (70.5 KB)
For the userform display code:
        'SendKeys "i"
        'Exit isolate
        UserformQuitter.Show vbModeless
And for the code of UserformQuitter (with a button named Button1)
It's perfect, it's exactly what I needed. :slight_smile:
Would it be possible for this userform to be centered in the SW window to find it easily, because it is a little bit everywhere :confused: depending on the user if there are 1 or 2 or 3 screens. I tried a trick to center that I had for a userform on excel but it doesn't work here.
Hello
You need to add a procedure in the code, see this topic: Centering a userform on a screen - Macro - myCAD Forum
No, what works on Excel does not work on SW.
To center the window in relation to the screen used is very complicated on SW.
See this topic and @m_blt's answer once again:
forum.mycad.visiativ.com/t/centrer-un-userform-sur-un-ecran/108560?lang=fr
Thank you, I just looked at the subject. I have applied what must be done. it works well for the userformLeaves it is well centered. I did the same thing for my 2nd userformChoix but there it doesn't work it tells me that it can't find the window to be able to center. Do you know what would have to be changed?
Insulate room without hardware.swp (117.5 KB)
Hello
For my part, I put the function call in each userform in the activate procedure:
Private Sub UserForm_Activate()
CoincidentsCtresWindows "SOLIDWORKS", xxx.Caption, True
it's perfect, it works, thank you :blush:
The advanced selection tool (standard in solidworks) allows you to select parts based on a property, then simply right-click in the vacuum and isolate :ok_hand:t2:
