Mam makro z częścią, która ukrywa frezowanie na europ, to makro opracowane dzięki @JeromeP na ten temat:https://www.lynkoa.com/forum/solidworks/macro-cacher-les-cercle-de-fraisure-assistance-de-per%C3%A7age
Z tym, że to makro usuwa 2 otwory, które nie są frezowane i dlatego nie powinny być wykrywane.
Załączam część i mep, który powoduje problem, a także użyty kod:
Option Explicit
Sub HideFraisage()
Dim swapp As SldWorks.SldWorks
Dim swDraw As SldWorks.DrawingDoc
Dim swView As SldWorks.View
Dim vComps As Variant
Dim vComp As Variant
Dim Comp As SldWorks.Component2
Dim vEdges As Variant
Dim vEdge As Variant
Dim swEdge As SldWorks.edge
Dim swCurve As SldWorks.Curve
Dim IsClosed As Boolean
Dim pos As String
Dim CurveParam As Variant
Dim Cercle As Class1
Dim monCercle As Class1
Dim Cercles As Collection
Dim Resultat As Variant
Dim m As Double
Set swapp = Application.SldWorks
Set swModel = swapp.ActiveDoc
Set swDraw = swModel
Set swView = swDraw.GetFirstView.GetNextView
'Set swView = swDraw.ActiveDrawingView
'If swView Is Nothing Then
'MsgBox "Selectionner une vue"
'Exit Sub
'End If
'Ajout SD pour récuperer les valeures de la Bounding Box (Longueur Largeur épaisseur)
Dim swPartModel As SldWorks.ModelDoc2
Set swPartModel = swView.ReferencedDocument
Resultat = GetPreciseBoundingBox(swPartModel)
' Fin de l'ajout
'On r
Set Cercles = New Collection
vComps = swView.GetVisibleComponents
For Each vComp In vComps
Set Comp = vComp
vEdges = swView.GetVisibleEntities(Comp, swViewEntityType_e.swViewEntityType_Edge)
For Each vEdge In vEdges
Set swEdge = vEdge
Set swCurve = swEdge.GetCurve
If swCurve.IsCircle Then
swCurve.GetEndParams Empty, Empty, IsClosed, Empty
If IsClosed Then
CurveParam = swCurve.CircleParams
pos = ""
If Round(CurveParam(3), 5) = 0 Then pos = pos & Round(CurveParam(0), 5) & "-"
If Round(CurveParam(4), 5) = 0 Then pos = pos & Round(CurveParam(1), 5) & "-"
If Round(CurveParam(5), 5) = 0 Then pos = pos & Round(CurveParam(2), 5) & "-"
'Debug.Print pos
Set Cercle = New Class1
Cercle.pos = pos
Cercle.dia = (Round(CurveParam(6), 10)) * 1000
Set Cercle.edge = swEdge
Cercles.Add Cercle
End If
End If
Next
Next
swModel.ClearSelection2 True
For Each monCercle In Cercles
For Each Cercle In Cercles
If Cercle.pos = monCercle.pos And Cercle.dia < monCercle.dia And (monCercle.dia * 2) < (Resultat(1) - 2) Then
monCercle.edge.Select4 True, Nothing
End If
Next
Next
'On cache le cercle
swDraw.HideEdge
swModel.ForceRebuild3 False
Function GetPreciseBoundingBox(part As SldWorks.PartDoc) As Variant
Dim dBox(2) As Double
Dim vBodies As Variant
vBodies = part.GetBodies2(swBodyType_e.swSolidBody, True)
Dim minX As Double
Dim minY As Double
Dim minZ As Double
Dim maxX As Double
Dim maxY As Double
Dim maxZ As Double
Dim First As Integer, Last As Long
Dim j, k As Long
Dim temp As Double
If Not IsEmpty(vBodies) Then
Dim i As Integer
For i = 0 To UBound(vBodies)
Dim swBody As SldWorks.Body2
Set swBody = vBodies(i)
Dim x As Double
Dim y As Double
Dim z As Double
swBody.GetExtremePoint 1, 0, 0, x, y, z
If i = 0 Or x > maxX Then maxX = x
swBody.GetExtremePoint -1, 0, 0, x, y, z
If i = 0 Or x < minX Then minX = x
swBody.GetExtremePoint 0, 1, 0, x, y, z
If i = 0 Or y > maxY Then maxY = y
swBody.GetExtremePoint 0, -1, 0, x, y, z
If i = 0 Or y < minY Then minY = y
swBody.GetExtremePoint 0, 0, 1, x, y, z
If i = 0 Or z > maxZ Then maxZ = z
swBody.GetExtremePoint 0, 0, -1, x, y, z
If i = 0 Or z < minZ Then minZ = z
Next
End If
x = (maxX - minX) * 1000
y = (maxY - minY) * 1000
z = (maxZ - minZ) * 1000
'Debug.Print "x=" & x
'Debug.Print "y=" & y
'Debug.Print "z=" & z
dBox(0) = x: dBox(1) = y: dBox(2) = z
First = LBound(dBox)
Last = UBound(dBox)
For j = First To Last - 1
For k = j + 1 To Last
If dBox(j) > dBox(k) Then
temp = dBox(k)
dBox(k) = dBox(j)
dBox(j) = temp
End If
Next k
Next j
'Debug.Print "Longueur:" & dBox(2)
'Debug.Print "Largeur:" & dBox(1)
'Debug.Print "Epaisseur:" & dBox(0)
GetPreciseBoundingBox = dBox
End Function
Początkowo myślałem, że symetryczne położenie 2 okręgów oznacza, że nie wykrył - na jednej z 2 pozycji i że dlatego uważa, że 2 okręgi są nałożone, więc dodałem 2 inne okręgi symetrycznie na początku części i są one traktowane tak, jak powinny być (ignorowane)
Więc nie bardzo rozumiem, czy ktoś ma pomysł na ten temat.
pb_trou_2.zip
