Bonjour;
J'ai trouvé (sur le site de https://www.codestack.net/) une petite macro qui remet les compteurs des fonctions et des esquisses à Zero.
Seulement, et mes conaissances limitées en Macro ne me le permettent pas encore, je voudrai pouvoir exclure de ces renommages quelques fonctions.
par exemple "Trou taraudé ".
Merci de l'aide que vous pourrez m'apporter.
Sub main()
Set swModel = swApp.ActiveDoc
Dim passedOrigin As Boolean
passedOrigin = False
Dim featNamesTable As Object
Dim processedFeats As Collection
Set featNamesTable = CreateObject("Scripting.Dictionary")
Set processedFeats = New Collection
featNamesTable.CompareMode = vbTextCompare 'case insensitive
Set swFeat = swModel.FirstFeature
While Not swFeat Is Nothing
If passedOrigin Then
If Not Contains(processedFeats, swFeat) Then
processedFeats.Add swFeat
RenameFeature swFeat, featNamesTable
End If
Dim swSubFeat As SldWorks.Feature
Set swSubFeat = swFeat.GetFirstSubFeature
While Not swSubFeat Is Nothing
If Not Contains(processedFeats, swSubFeat) Then
processedFeats.Add swSubFeat
RenameFeature swSubFeat, featNamesTable
End If
Set swSubFeat = swSubFeat.GetNextSubFeature
Wend
End If
If swFeat.GetTypeName2() = "OriginProfileFeature" Then
passedOrigin = True
End If
Set swFeat = swFeat.GetNextFeature
Wend
Else
MsgBox "Please open model"
End If
Sub RenameFeature(feat As SldWorks.Feature, featNamesTable As Object)
Dim regEx As Object
Set regEx = CreateObject("VBScript.RegExp")
regEx.Global = True
regEx.IgnoreCase = True
regEx.Pattern = "(.+?)(\d+)$"
Dim regExMatches As Object
Set regExMatches = regEx.Execute(feat.Name)
If regExMatches.Count = 1 Then
If regExMatches(0).SubMatches.Count = 2 Then
Dim baseFeatName As String
baseFeatName = regExMatches(0).SubMatches(0)
Dim nextIndex As Integer
If featNamesTable.Exists(baseFeatName) Then
nextIndex = featNamesTable.item(baseFeatName) + 1
featNamesTable.item(baseFeatName) = nextIndex
Else
nextIndex = 1
featNamesTable.Add baseFeatName, nextIndex
End If
feat.Name = baseFeatName & nextIndex
End If
End If
Function Contains(coll As Collection, item As Object) As Boolean
Dim i As Integer
For i = 1 To coll.Count
If coll.item(i) Is item Then
Contains = True
Exit Function
End If
Next
Contains = False
End Function
MacLane.
renommer_feature-part.swp
