I will know how to make a macro that would allow us to generate PDF plans.
We save our PDFs in a separate folder from the solidworks plan folder.
And we'd like to be able to choose which pages to export.
Do you have a macro model made on this profile?
Thank you in advance.
Here's one of the macros I use
Dim swModel As ModelDoc2
Dim lErrors As Long
Dim lWarnings As Long
swModel.Extension.SaveAs GetFilename(swModel.GetPathName) & " rev." & swModel.GetCustomInfoValue("", "Révision") & ".pdf", swSaveAsCurrentVersion, swSaveAsOptions_Silent, Nothing, lErrors, lWarnings
Function GetFilename(strPath As String) As String
Dim strTemp As String
strTemp = Mid$(strPath, InStrRev(strPath, "\") + 1)
GetFilename = Left$(strTemp, InStrRev(strTemp, ".") - 1)
End Function
Or this one that saves the PDFs of all the plans in C:\pdf files when you run it from the assembly.
Sub ShowAllOpenFiles()
Dim swAllDocs As EnumDocuments2
Dim FirstDoc As SldWorks.ModelDoc2
Dim dummy As Boolean
Dim NumDocsReturned As Long
Dim DocCount As Long
Dim i As Long
Dim sMsg As String
Dim bDocWasVisible As Boolean
Dim OpenWarnings As Long
Dim OpenErrors As Long
Dim DwgPath As String
Dim myDwgDoc As SldWorks.ModelDoc2
Dim drwPathName As String
Dim pdfPathName As String
Dim pdfFolderName As String
Dim lErrors As Long
Dim boolstatus As Boolean
DocCount = 0
swAllDocs.Reset
While NumDocsReturned <> 0
DwgPath = swDoc.GetPathName
Dim fso As Scripting.FileSystemObject
MkDir pdfFolderName
'Exit Sub
Dim Part As ModelDoc2
Set Part = swApp.ActiveDoc()
'You have a drawing active
If ("" = drwPathName) Then
' GetPathName() was empty
Exit Sub
pdfPathName = fso.BuildPath(pdfFolderName, fso.GetBaseName(drwPathName) + ".pdf")
Debug.Print pdfPathName
swApp.QuitDoc (Part.GetTitle)
Set myDwgDoc = Nothing
DocCount = DocCount + 1
Wend
Or if you export from solidworks, there is a batchconverter tool from Mycadservice for which you have a subscription.
See even Integration which allows you to do something more complicated (for example from an excel bill of materials to retrieve from an assembly it is possible to retrieve the quantity to be entered in a plan before exporting it in pdf. (same thing for a business number, a customer...)
