Macro solidworks pour chercher et supprimer un anotation en fonction d'une valeur
Je souhaiterais de l'aide afin de chercher et supprimer une note (sur plusieurs feuille) qui commence par "Graver*"
J'arrive à trouver la note, mais pas à la sélectionner et l'effacer pour l'instant, il y a surrement un truc tout bête que je ne comprend pas:
' Preconditions: Drawing document is open and at least
'                one view has some notes.
' Postconditions: None
' NOTE: IDrawingDoc::GetViews returns both sheets and views.
Option Explicit
Dim swDrawDoc As SldWorks.DrawingDoc
Dim swView As SldWorks.View
Dim swNote As SldWorks.Note
Dim sheetCount As Long
Dim viewCount As Long
Dim noteCount As Long
Dim i As Long
Sub main()
Set swModel = swApp.ActiveDoc
Set swDrawDoc = swModel
viewCount = swDrawDoc.GetViewCount
Dim ss As Variant
ss = swDrawDoc.GetViews
For sheetCount = LBound(ss) To UBound(ss)
    Dim vv As Variant
    vv = ss(sheetCount)
    For viewCount = LBound(vv) To UBound(vv)
        Debug.Print (vv(viewCount).GetName2())
        Dim vNotes As Variant
        noteCount = vv(viewCount).GetNoteCount
        If noteCount > 0 Then
            vNotes = vv(viewCount).GetNotes
            For i = 0 To noteCount - 1
                Debug.Print "  Note text: " & vNotes(i).GetText
                If vNotes(i).GetText Like "Graver le N°*" Then
                MsgBox "ok"
                'Dim myAnnotation As SldWorks.Annotation
                'Set myAnnotation = myNote.GetAnnotation
                'myAnnotation.Select3 False, Nothing
                'Part.Extension.DeleteSelection2 1
                End If
            Next
        End If
    Next viewCount
Next sheetCount
Avec un peu de recherche, voici un code presque fonctionnel:
Option Explicit
Sub SupressNote()
Dim swDraw                      As SldWorks.DrawingDoc
Dim swAnn                       As SldWorks.Annotation
Dim bRet                        As Boolean
Dim mySheet                     As SldWorks.Sheet
Dim swSheet                     As SldWorks.Sheet
Dim vSheetNames                 As Variant
Dim i As Integer
    Set swDraw = swModel
    Set swSheet = swDraw.GetCurrentSheet
    vSheetNames = swDraw.GetSheetNames
    For i = 0 To UBound(vSheetNames)
    Debug.Print vSheetNames(i)
    swDraw.ActivateSheet vSheetNames(i)
                    Set swView = swDraw.GetFirstView ' This is the drawing template
                    Set swNote = swView.GetFirstNote
                    swModel.ClearSelection2 (True)
                    Debug.Print "File = " & swModel.GetPathName
                    Do While Not swNote Is Nothing
                        Debug.Print "Note:" & swNote.GetText
                        If swNote.GetText Like "Graver le N°*" Then
                            Set swAnn = swNote.GetAnnotation
                            bRet = swAnn.Select2(True, 0)
                            Debug.Print "  " & swNote.GetName
                            Debug.Print "    " & swNote.GetText
                            swModel.EditDelete
                        End If
                        Set swNote = swNote.GetNext
                    Loop
                    swDraw.ActivateSheet (swSheet.GetName)
    Next i
    'Supression du calques Notes rouges
     Dim lyrMgr As LayerMgr
     Set lyrMgr = swDraw.GetLayerManager
    bRet = lyrMgr.DeleteLayer("NotesRouge")
Il me reste juste un soucis car l'annotation est en double dans chaque feuille et il ne me supprime que la 1èere si quelqu'un comprend pourquoi.
Actuellement je lance 2 fois la macro pour nettoyer chaque MEP (plusieurs centaine de feuilles...)
J'étais en train de tester la même piste, donc pour le fait que ça ne supprime pas la seconde c'est le fait qu'une fois la suppression de la note effectuée, swNote est vide.
Ci-dessous le code corrigé avec l'ajout d'un booléen pour gérer la poursuite de l'analyse des notes.
Sub SupressNote()
Dim bRet                        As Boolean
Dim bFind                       As Boolean
Dim i As Integer
                    Do While Not swView Is Nothing
                            bFind = False
                            If swNote.GetText Like "*Chanfrein*" Then '"Graver le N°*" Then
                                bFind = True
                                swModel.EditDelete
                            End If
                        If Not bFind Then Set swNote = swNote.GetNext
                        Loop
                    Loop
    Next i
Edit: Si les notes ne sont pas systématiquement dans le fond de plan, il faut également penser à boucler sur les vues.
Les notes (dans ce cas là sont bien dans le fond de plan)
La solution proposée est parfaitement fonctionnelle. Merci
