Macro solidworks?
So I downloaded the 2 (attachment), as well as "activate all configuration" in formatl .html
So it's .swp files but an error message that no program can read it appears
However, once opened in solidworks with macro tool
A window appears and I would like to have information about these features
This window appears (see attachment)
It's very simple, open a room and press Tools/Macro/run. In the box that opens, you may need to change the type of files to be opened to select swb or swp.
Note that this type of file can also be sent to you for 3D instead of STEP or IGES. Festo offers this for its cylinders, for example. As a result, you don't have dead bodies but real construction trees.
Edit: Of course, you must first have saved the .swp or .swb file on your computer.
But what's the point?
It is used in particular to do repetitive operations automatically, to save time, or even operations that cannot be done manually.
The macro you are talking about seems, as its name suggests, to activate all configurations. Without them, you have to activate them one by one. If you have a hundred of them on a heavy assembly, by hand you spend a day on it, with this macro, you launch it in the evening when you leave work and the next morning it's done.
For Feature Masse, it is the MyCADServices ancestor of the SW center of gravity that can be found today as a base. Before SW13, this feature did not exist. So I think @jmsavoyat is at the origin of this macro. You make a 3D sketch with just 1 point. You launch the macro and select this point. You validate and the macro will reposition the point at the center of gravity. The action that must have been done is that the macro took the coordinates of the center of gravity and filled them in on the point of your 3D sketch! This is very useful when you are drawing a rudder pedal for example.
@ benoit
and in case I want to create one, (see attachment)
What can I enter as a parameter?
What are important?
Here, the question is much too vague! The pros will certainly tell you (@Lucas and @jfaradon) before throwing yourself headlong into the code, you must already know what you want to do. It's also about design: you don't start drawing in 3D without having scribbled a crobard on a piece of paper. Macros are the same.
So what do you want to do with this macro?
There are some tutorials there: http://www.lynkoa.com/search/Macro?type[0]=tutorial you can take a look.
First of all, know what it's for (and you told me thank you)
then have information to be able to use it if necessary
That's all
So in my opinion, this question is closed. If you have a macro "project", it's better to redo a question describing it for more readability and to avoid it going in all directions.
Now, be careful not to try to do everything with macros. SolidWorks is sufficient in many cases without resorting to that.
So to sum up, look at the tutorials if there is one that talks about the basics of macros. And if you have a particular need, write it down first. From there, we will be able to see which solution to move towards.
to my tutorials!!
I don't understand. I thought I had answered your question?
Duplicate
@ Nicolas
+1 for the question
-1 for your answer that doesn't mean anything
Edit I thought that benoit had given the answers
Hello Nicolas,
The correct answer should usually be taken from the answers given by the contributors. I do think that @Benoit has largely contributed to guiding you in your research. It would have been normal to assign him the correct answer. That's the principle! Think about it next time!
sorry for @benoit
it's true that these answers have guided me, but I still can't use or create my macro,
So I downloaded others and I rated and commented on them (which also gives points)
So I'll ask a more specific question next time
Regards nicolas
@nicolas it's not time the points it's the recognition of the help. Moreover, the best answer is at the top of the list so imagine that those who are looking for the same subject as you when they consult your question can miss the relevant answers which, as you say, are we directing
Make an edit of your answer and make at least one plagiarism of Benoit's answer as a quote
For this time he won't blame you I'm sure. Laughing out loud
@gerald
I don't understand your post!
Re-edit a question?
but I didn't get a clear answer!
After my question maybe wasn't, so be it!
I appreciate the help provided (I rate the answer)
but I'm still hungry
Sincerely, Nicolas
@nicolas I talked about editing the answer not the question.
@ gerlad
I can't  re-edit my  "best answer"
the others yes but not this one
Anyway, I'm going to ask another question
