Hi all!
I'm new to the forum, I was looking for a forum french on Inventor to help me with a problem and I came across Lynkoa :). I 've been working for 15 years on Catia (car plastic part) but now, I need to analyze an assembly on Inventor and I'm completely lost ....
Let me explain!
I have a ring with "elastic" legs and a shaft with ramps (0.5mm high)
Once assembled, when I turn the gray ring, the legs slide on the shaft and come to position themselves on the railings. In this position, the legs are deformed by 0.5mm.
That's the principle, now I'm trying to determine the torque needed to turn this ring To limit this torque, I can resize the lugs. To limit this torque, I can resize the legs.
Can someone help me? (even if it's not via Inventor, it will still guide me a little ;) )
Thank you in advance,
Greg
PS: attached the *.spt of the parts
ring-shaft.stp
