STL Drawing
Ourir piece by piece, super long....
I was also thinking of a macro that would do it for me^^
No Mycad tools for that?
When I export the parts one by one, feature works is grayed out... What for?
The problem I think is that you have an assembly of parts in surface
Do these pieces interpenetrate each other or not?
Have you tried to open the first file (imported 1) alone to see the head it has
and convert it to solid to already allow you to analyze the workload to be expected
Export your set
and suppresses everything except the 1st imported piece
to test
Precisely, when I insert it in a new part, I can't do anything with it except convert it into a fake sheet metal (because it's a badly designed part)
I would just like to be able to have the profile of each piece on a plan to be able to redraw everything easily in having to take 50,000 ribs by hand...
The part contains unsupported body operations.
FeatureWorks was unable to continue.
I don't know if it can help you, but there was a post on how to import surfaces into a MEP:
http://www.lynkoa.com/forum/import-export-formats-neutres/mise-en-plan-dun-step-impossible
On the other hand, we will have to rate everything.
Thank you, but the problem is not so much the quotation but above all the export of all the parts and their own mep.
I have exactly 167 pieces, I have some for the day see more^^
To sum up, it would be necessary to:
- a macro that records all the volume bodies in single pieces
- then of these bodies, that a drawing be created with an import of dimensions.
If it's not possible to import the ribs, I'll take them back by hand, but at least I'll already have a good part base
Well, by right-clicking on the list of parts and then "save parts"
I have my unit parts list numbered from 1 to 167
All that remains is to do automatic drawings with predefined views?
Smart drawing can do it, right?
On the other hand, Smartdrawings, I didn't get everything^^
I configure everything, I launch the bousin, it thinks for 10 hours, it opens a lot of shots, closes them etc.
But I can't find them anywhere, even if I have specified a precise path.
Since these are imported bodies, there cannot be any dimensions from the model.
I'm not worth the hills, I even unticked the box.
I just want to have my views positioned ^^
Here is the Smart drawings log error
Exception Found:
01-26 02:47
Type:     System.NullReferenceException
HelpLink:
Message:     Object reference not set to an instance of an object.
Source:     SmartDrawings
StackTrace :        at myCADtools2016.RD.Tools.SmartDrawings.frmMain.swfbApply_Click(Object sender, EventArgs e)
TargetSite:     Void swfbApply_Click(System.Object, System.EventArgs)
__________________________________________________________________
Are your parts volumes (so not "weird" surfaces or bodies)?
On a piece that you can plan by hand, does smart drawing work?
I took the full .sat (yes in fact it's a .sat)
I clicked on "Volumetric body" and I did "save bodies"
From there I open all the volume bodies with smartdrawings and when I launch, I have the error described
hooouuuu @ bart -1000
Lol :D
Help me instead of fucking with me ^^ xD
Now that you have your . Sat try to open the first one and see what happens
@+è
I have all my parts imported in sldprt
I can do the MEPs automatically, that's ok.
Last problem, the scale of views... How do you make sure that the views are neither very small nor scale 1?
