h34i
November 14, 2019, 8:06pm
1
I'm looking to modify this stp file (part of a drone) to fix components on the inside wall of this "hood".
Could you help me convert/rebuild this file so that I can build shapes based on the inner wall of the hood...?
Thank you in advance, I am a novice with solidworks (computer engineer by training, I use solidworks only for 3d modeling of parts to be printed...).
tarot_cover.stp
HELLO
There' s FeatureWorks that recognizes functions and rebuilds the creation tree.
h34i
November 15, 2019, 6:40pm
3
Good evening
Thanks for the info, when I try to use featureWorks; The "Recognize Functions" function is disabled.
The import tool seems to be run automatically successfully.
An :) idea?
Zozo_mp
November 15, 2019, 7:00pm
4
Good evening
Look here http://help.solidworks.com/2012/french/SolidWorks/fworks/t_accessing_featureworks_commands.htm
Kind regards
h34i
November 15, 2019, 7:11pm
5
I checked that the add-in is active (with restarting solidworks), but the option still seems to be dissatisfied (previous message screenshoot)
Hello
It seems to me that from the screenshots it's a part of a future version and not a dead body.
Can you share the file so we can take a look at it?
d_roger
November 15, 2019, 8:17pm
7
Hello
SW2019 version, I would rather say that it's a step file imported with the "Interconnect 3D" function enabled, in plain English it's a step file in an assembly, a bit like a virtual file so:
- Disable the "Interconnect 3D" function, see HERE .
- Re-import the step file into Solidworks.
- Launch the recognition of function.
Kind regards
h34i
November 15, 2019, 8:33pm
8
The stp file is in PJ of my very first message.
The import diagnosis seems to find problems.
d_roger
November 15, 2019, 10:04pm
9
You click on the "Try to repair everything" button, then if everything is repaired, you launch your function recognition...
h34i
November 15, 2019, 10:08pm
10
Already tried, there are defective faces
d_roger
November 15, 2019, 10:07pm
11
Here is your part after import diagnosis and function recognition, but hey, it doesn't recognize much and a large part remains imported...
Kind regards
tarot_cover.sldprt
h34i
November 15, 2019, 10:14pm
12
I saw your message after I posted mine.
Thanks for the part, I'm attaching the stl version if it can work better...
tarot_cover.stl
d_roger
November 15, 2019, 10:34pm
13
It inserts a graphic object with which I can't do anything, I tried again on the step by changing the options and I didn't get better than the part already provided...
Kind regards
