Macro modificatie "fix sets en subsets"
Hallo;
Hier is een volledige macro (om toe te voegen aan de jouwe) voor "gearceerde randen" en opname:
Public Enum swViewDisplayMode_e
swViewDisplayMode_Wireframe = 1
swViewDisplayMode_HiddenLinesRemoved = 2
swViewDisplayMode_HiddenLinesGrayed = 3
swViewDisplayMode_Shaded = 4
swViewDisplayMode_ShadedWithEdges = 5 ' only valid for a part
End Enum
Const nNewDispMode As Long = swViewDisplayMode_ShadedWithEdges
Dim swModView As SldWorks.ModelView
Dim bRet As Boolean
Dim swerror As Long
Dim swwarnings As Long
Set swModView = swModel.ActiveView
swModView.DisplayMode = nNewDispMode
Debug.Assert nNewDispMode = swModView.DisplayMode
swModel.ShowNamedView2 "*Isometric", 7
swModel.ViewZoomtofit2
swModel.ForceRebuild3 False
Debug.Print "File = " & swModel.GetPathName
Debug.Print " Display mode = " & swModView.DisplayMode
Debug.Print " ModelView hWnd = " & swModView.GetViewHWnd
Debug.Print " ModelView DIB = " & swModView.GetViewDIB
swModel.Save3 swSaveAsOptions_e.swSaveAsOptions_Silent, swerror,swwarnings
swApp.CloseDoc (swApp.ActiveDoc.GetPathName)
Vriendelijke groeten.
Hallo @Maclane ,
Ik heb het uiteinde van de macro aan de mijne gelijmd, maar er gebeurt niets als ik hem start.
    Dim swModel As ModelDoc2
    Dim swAssy As AssemblyDoc
    Set swAssy = swModel
    TransverseComponents swAssy
    swApp.SendMsgToUser "Terminé" & Chr(10) & ":-)"
    swAssy.ForceRebuild2 (True)
Sub TransverseComponents(swAssy As AssemblyDoc)
    Dim vComponents As Variant
    Dim i As Integer
    Dim swComponent As Component2
    Dim swAssembly As AssemblyDoc
    vComponents = swAssy.GetComponents(True)
    For i = 0 To UBound(vComponents)
        Set swComponent = vComponents(i)
        Set swModel = swComponent.GetModelDoc2
        Debug.Print swComponent.Name2
        swComponent.Select4 False, Nothing, False
        swAssy.FixComponent
        If Not swModel Is Nothing Then
            If swModel.GetType = swDocASSEMBLY Then
                Set swAssembly = swModel
                TransverseComponents swAssembly
    Next i
End Enum
Dim bRet As Boolean
Dim swerror As Long
swModel.Save3 swSaveAsOptions_e.swSaveAsOptions_Silent, swerror, swwarnings
Hallo;
U kunt niet twee macro's met de naam "Main()" in dezelfde module hebben.
-optie 1: hernoem een van de macro's (degene die ik je heb gegeven), roep dan deze macro aan met het commando:
Roep TheMacroNameMacro aan
alleen met de "end sub" van de eerste "macro"
  • Optie nummer 2:
    Integreer de nieuwe macro in de oude:
    Verplaats de variabeledeclaraties (DIM's...) van de nieuwe macro net onder de regel "Optie expliciet" (helemaal bovenaan).
    Dubbele aangiften verwijderen... desnoods.
    en plak de regels van de nieuwe macro voor de "end sub" van de oude (door de naam van de nieuwe macro en de slotregel "end sub" te verwijderen...
    Wat zou moeten resulteren in iets als:
Dim bRet As Boolean
Dim swerror As Long
    Dim i As Integer
        swAssy.FixComponent
    Next i
End Enum
Opmerking: Als ik deze "standalone" macro heb verzonden, is dat zodat u deze kunt testen voordat u deze probeert te integreren in een andere... (u moet het altijd proberen voordat u "koopt").
Ik heb zojuist de macro gekopieerd en geplakt, maar er wordt niets gestart; dsl Ik ben een echte quiche in VBA :woozy_face: :woozy_face: :woozy_face:
Sorry dat ik niets weet over vba, maar hier is de code die werkt in C#
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows;
using System.Windows.Forms;
using SolidWorks.Interop.sldworks;
using SolidWorks.Interop.swconst;
namespace FixAssemblies
    public partial class SolidWorksMacro
        public ModelDoc2 swDoc = null;
        public AssemblyDoc swAssembly = null;
        public object[] vComponents = null;
        public Component2 swComponent = null;
        public ModelView swModView = null;
        public int Errors;
        public int Warnings;
        public void Main()
            swDoc = ((ModelDoc2)(swApp.ActiveDoc));
            swModView = (ModelView)swDoc.ActiveView;
            swAssembly = (AssemblyDoc)swDoc;
            TransverseComponents(swAssembly);
            swModView.DisplayMode = 5;
            swDoc.Save3((int)swSaveAsOptions_e.swSaveAsOptions_SaveReferenced, ref Errors, ref Warnings);
            swApp.SendMsgToUser2("Terminé\n:-)", (int)swMessageBoxIcon_e.swMbInformation, (int)swMessageBoxBtn_e.swMbOk);
            return;
        public void TransverseComponents(AssemblyDoc swAssy)
            vComponents = (object[])swAssembly.GetComponents(true);
            for (int i = 0; i < vComponents.Length; i++)
                swComponent = (Component2)vComponents[i];
                swDoc = (ModelDoc2)swComponent.GetModelDoc2();
                swComponent.Select4(false, null, false);
                swAssembly.FixComponent();
                if (swDoc != null)
                    if (swDoc.GetType() == (int)swDocumentTypes_e.swDocASSEMBLY)
        public SldWorks swApp;
Hier is de gewijzigde en werkende code op SW2022.
Dim bRet As Boolean
Dim swerror As Long
End Enum
    Dim i As Integer
        swAssy.FixComponent
    Next i
:grinning:Bravo @Cyril_f ... We kunnen op je rekenen. :+1:
Ik schaam me als ik nu naar mijn vorige post kijk... Ik had deze macro herschreven met mijn twee linkervoeten... :face_vomiting:
Het gebeurt. Ik heb ook een macro in productie gezet waarbij ik was vergeten een stukje testcode te verwijderen, dus alles was fout voor de gebruikers.
Hallo @Cyril_f ,
bedankt voor de macro, maar ik weet niet zeker of het de sub-ASM en PRT opslaat, want na het starten ervan repareert het zoals degene die ik heb en door het valideren van het venster dat bevestigt dat alles is opgelost, sluit het de ASM en wanneer ik het opnieuw open, is alles leeg, zelfs de sub-ASM.
Misschien een beetje snel getest. Ik heb geen export bij de hand om te controleren, kan ik er een delen?
@Cyril_f,
bijgevoegd een geteste ASM
BTW. STAP (3.2 MB)
Ik begreep het net, aangezien het bestand niet is opgeslagen, hoeft er geen back-up te worden gemaakt.
Twee opties: vooraf opslaan voordat de macro wordt gestart of een back-uppad instellen (door het te selecteren of een vast pad)
Sterker nog, ik dacht dat het haalbaar was met de macro. Vroeger zou ik de macro starten die alles oploste, vervolgens handmatig "Stopt in gearceerde afbeeldingsmodus" selecteren en gewoon op opslaan drukken zonder mapselectie of iets dergelijks.
Tenzij ik me vergis, kan de macro niet weten waar het bestand moet worden opgeslagen omdat het geopende bestand geen pad heeft. Er is geen " automatische " opname via macro zonder het pad ergens vandaan te halen.
Ik begrijp niet veel in macro, maar aangezien je de functie "Stop in gearceerde afbeeldingsmodus" selecteert (door erop te klikken), dacht ik dat je hetzelfde kon doen met opslaan (selecteren/drukken)
We kunnen dit emuleren en het zal een mapselectievenster openen alsof we op " Opslaan "
Ik heb zojuist de macro getest door eerst de assemblage op te slaan en de macro sluit de assemblage wanneer deze zijn werk voltooit. Als het ons lukt om het te laten werken zonder de assemblage te sluiten, kunnen we het zo laten; door alles te willen vereenvoudigen; het maakt het nog ingewikkelder
Je moet deze regel verwijderen aan het einde van het spel dat zich in Sub Main bevindt
Anders voor het mapselectievenster, op zich geen probleem, ik heb al een code die ermee wordt uitgevoerd als dat nodig is om deze toe te voegen
als het ons standaard lukt om de map te hebben waar de STEP vandaan komt, zou het goed zijn, maar verder is het het niet zo waard, want "hoe meer je klikt, hoe duurder het is"
