Hello
I'd like to know if there is a macro on solidworks for recording, of all the plans opened in session.
Thank you in advance
Hello
Hello; try to see this one but I don't know if it works...:
Dim swAllModel As ModelDoc2
Dim lErrors As Long
Dim lWarnings As Long
Sub main()
Set swAllModel = swApp.ActiveDoc
swModel.Extension.SaveAs GetFilename(swAllModel.GetPathName) & " rev." & swAllModel.GetCustomInfoValue("", "Revision") & ".pdf", swSaveAsCurrentVersion, swSaveAsOptions_Silent, Nothing, lErrors, lWarnings
Function GetFilename(strPath As String) As String
Dim strTemp As String
strTemp = Mid$(strPath, InStrRev(strPath, "\") + 1)
GetFilename = Left$(strTemp, InStrRev(strTemp, ".") - 1)
End Function
I just tested it and it doesn't work. I'm going to test it over the weekend unless someone gives you one. ;-)
Hello, I created a macro that makes all the PDFs of an assembly or there is one that makes all the PDFs of a folder, can it be suitable ?
@manu: ok thank you, I admit that I couldn't test this weekend.
@PL.: Yes, making PDFs in relation to a file can suit me.
Use SolidWorks Task Scheduler, it allows you to create tasks like export files or folders in the format you want and more you can schedule like put an export every Tuesday at 3 p.m
Here.
@matthieu: it's the planner of the premium version that allows this.
The standard lanifier is much more succinct:
Hello
Here's a macro that should work:
http://www.lynkoa.com/tutos/solidworks-creer-tous-les-pdf-pour-un-dossier-0
Hello
I tried the macro of .PL because your idea is very practical.
But .PL's macro doesn't work. There is a compilation error at SUB main path = BrowseFolder, .PL!
But otherwise it's a good job.
Well done
@PL: I can't stop knowing where to indicate the source file
Hi all
Sorry I won't be able to update the macro until next week!
