MYCADTOOLS - Tolerances - Updating the derived configuration
Hello
With the MYCADTOOLS Tolerance tool, I created a configuration derived from my model in dimensions and average tolerances.
When I change the parent model (dimensions and tolerances), how do I update the derived configuration WITHOUT deleting it?
The tolerance tool is bugging on my computer, so it's not possible to test it for me.
It seems to me that by relaunching the tool, the derived configuration is updated.
If necessary, go through a test part (copy under) to check, and not risk the problem on your part in production.
It doesn't work.
You mean that it doesn't update when you restart the utility?
If this is the case you may have to open a ticket with Visiativ, for me this is the behavior that the software should have.
Unless @fmarchand myCad utility specialist, or one of his colleagues, comes by to confirm the problem or explain how to make it work in case of a change in tolerances.
Hello
The calculation that is done by Tolerances allows you to create a configuration and calculate the dimensions at time T, but there is no link with the parent configuration. The dimension is then linked to the configuration:
So it's the SOLIDWORKS methodology that forces the tool to work like this. We are forced to delete the derived config to recreate it.
Kind regards
@fmarchand for the moment t yes I understood correctly, but instead of deleting the configuration couldn't it modify the dimensions of the existing configuration or at least say that the configuration is already existing and that it should be deleted and then restarted.
Hello Mr. MARCHAND
Thank you for your explanations.
Deleting and recreating the configuration is not a problem for the drawing, which regains the configuration.
After applying the " average" odds calculation, the odds with adjustments of the type h7, g6 are indeed modified in the derived configuration but are no longer active in the parent configuration (0/0)!
Moreover, can we have a micron precision for these adjustments?
Could you also explain to me the " reset " function and this slider which by default is " 50 "?
Hello
Indeed it's not normal that it doesn't keep the H7/g6 tolerance.
I have opened a request:
- 75594 - Dimensions with an H7/g6 Adjustment Are Changed When the Derived Configuration Is Created
The " reset " button allows you to return to the adjustment that was there before clicking on " Maxi Rating" or " Minimum Rating" or " Average Rating ".
The slider is linked to the " Percentage " button and allows you to calculate a percentage of the value of a dimension.
Example with a percentage of 50%.
Calculation of the percentage of 50% for the odds of 19.90 (Initially 20 +0.1/-0.3):
The maximum being 20.10 and the minimum being 19.70, a percentage of 50% gives 19.90 +0.2/-0.2
Kind regards
