Hello,
Since a PDMrestart, when I use a MyPDMtools, for example PDMproperties from PDM, nothing is displayed.
Do you have any ideas to correct this problem?
Thank you.
Hello,
Thank you.
Hello;
Try a repair of the installation of your MyPDMtools through the control panel manager.
Hello,
Thank you, I tried but I only have MyCADtools on the control panel.
I tried to repair the Solidworks 2025 installation but the PDMtools still doesn't work.
well... try the repair of MyCADtools tools, I imagine that the PDM part is an option of the classic Mycad tools (note: the Solidworks repair is not very interesting here).
Check if, in the tray system, the Mycad tools (maycadtools and/or Mycadpassport) are not open, if this is the case they will have to be closed.
Following an exchange with Visiativ, the problem comes from the Logi Option software (my mouse configuration software) which prevented me from deleting files in the cache during PDMrestart.
The files once deleted made it possible to solve the problem. I still have trouble understanding the connection, but it works.
