Hello,
Between the new version 2026 SP2.1 and version 2025 SP1, the table templates are no longer in XML but in MCTSB. How can I find my tables?
Do I have to do them again?
Thanks in advance
During a version test with the hotline, the person from the hotline transformed or imported our xml template.
As there were other bugs (in other parts) we stayed in 2024.
So transformation possible but I don't know how!
And not having the version anymore, it was not possible to look for me.
Hello;
Their *.mctsb format is just an encapsulation with a new root, if you rename the file to *.xml you will find yourself small.
you will just have to remember to change the root of the file after modifications...
I can rename my .xml files to .mctsb and convert my .mcbom project from old version to new. But I end up with a message " there is an error in the XML document (2, 2) "
I had to recreate all my Smartbom projects on the new version because of this type of error.
and it was a hell of a job...
And there are still a lot of errors on *.xlsm exports (spaces are added as a prefix on properties added in fixed cells...
See with the hotline if they can convert your table models cleanly...
