Hello
Is it possible to retrieve all the paths from the settings file locations in order to put them in an excel file?
Thank you in advance for your feedback.
Kind regards
Yannick
Hello
Kind regards
Yannick
Hello Yannick,
Using the SolidWorks Settings Copy Wizard, it is possible to export all settings as a *.sldreg file (text format).
References to the folders are in my house under the "[HKEY_CURRENT_USER\Software\SolidWorks\SOLIDWORKS 2019\ExtReferences]" section.
All you have to do is copy/paste all this and cut the lines using the "Data/Convert" function in Excel using "=" as a separator between the keys and the values.
When there are several files filled in for a single key, it is possible to separate them with the "; ".
M.
Thank you.
