Hello
Recently, when I open an assembly, it automatically puts all the parts in light.
I can't find how to open my assembly normally in solved
Hello
From solidworks (not windows explorer) just choose Solved mode before clicking open:
In general, it does it via a heavy assembly
See Block bar for shares
Otherwise in the assembly system option you can raise the threshold to switch to complex mode and other.
yes okay thank you from the explorer I can see the mode solved or not,
The problem is that it's the light mode that is as in preference
via shortcuts, the opening is done in light, and this has been the case recently.
Hello
See which options are selected in "System Option/Performance" and then under "Assembly".
Kind regards
