Opening STEP file
Hello
I have a problem on solidworks for opening and creating files. STEP. When I create a STEP, it is impossible to open it even on another computer (see error message).
If I want to open a STEP that comes from trace part or elsewhere I get the same message while the other station has no problem opening the file.
thank you for your help it's quite penalizing...
When recording, in the window where you choose the name of your step, below there is the options box.
You have to adjust the step to have volume. check the box with volume.areal geometry
How do you open the WWTP?
Because sometimes the "drag" function in the window does not open the STEP
If @Bart's solution is not enough,
Thoughtless solution: Retrieve your colleague's SW setting (Start/All Programs/SolidWorks/SolidWorks Tools/Wizard to copy the settings.) and reload it on your computer!
Hello
As Bart says, when opening or recording take a good look at the options in the window opening and recording. To make sure the options are displayed, select STEP in the file types because if you stay on all the files you won't have the options.
indeed I have the same parameters as you BART...
For the parameters I had thought about it but we don't have the same ones and it bothers me to put his own but if I have no choice....
I drag it, but I wait a little before letting go of the mouse button.
I've never had any problems.
Oh I understand the reluctance, but you can select what you want to recover, you can for example only recover the "system options" from the .sldreg file.
You can always put the old settings back later. ;)
In any case, without volume or surface functions, you won't get anywhere.
So it doesn't come from the parameters, I took those of my colleague it doesn't change anything...
in addition to what you say @ Bart
Often the problem comes from autocad files with double lines
What files do you want to open?
This will allow you to make an opening test via another person
and give you + info to see where the problem is
Send your file;)
Attached is the file I created from my position.
m1216_433_ouvercle_commande.step
Attached is the file that my colleague created, he opens it, not me...
m1216_433_ouvercle_commande-1.step
And can you send the piece? At home I manage to open your colleague's, but not yours.
Are you sure of your export options?
Have you tried the 2 different steps? AP214 and AP203?
Well compared to the view you showed me, yes I did check volume/surface geometry. (the same as my colleague).
m1216_433_ouvercle_commande.sldprt
same for me under SW 2012 the 2nd OK no problem
the 1st is no volume so your export must not be correct
I can't open your future version SW file for me
Sorry
I'm talking about that
Here, see if you can open them
desktop.rar
