I just joined a company that works under TopSolid. They have to upgrade the software ... and the question arises whether to do this upgrade or to switch to Solidworks (basically, it's now or never!)
So, in order to see more clearly, what are the points to keep in mind to make the decision? For those who have made the switch, have you encountered any unexpected problems?
And finally, what about the database? Is there a kind of " large mixer " that allows everything to be switched to STEP?
The question was asked at our company 15 years ago since we had 2 separate design offices (following a company takeover) on TopSolid and SW. We had weighed the pros and cons of the 2 softwares. For Topsolid: The advantages were CAM (used for the mecha part of our machines), faster for large drawings but less easy to modify from an assembly. The defect of switching to the topsoli 7 version (from memory) broke the whole (catastrophic) principle of topsolid sketches (the famous concatenated sketch was mandatory) For SW easier to hire, more user-friendly very simple sketch. In addition, we started at that time to develop automatic launches under SW thanks to the visiativ utility (non-existent under topsolid) and then in SW macro.
We are 2 users. For the volume, I can't say too much... especially since it works a lot per case (one-shot). And as a result, I'm not even sure that a full transfer is necessary.
It's not really a problem with TopSolid. I'm starting with it, so obviously I'm fumbling around a lot... but my colleague who has been working with it for years seems to be at the same level. So, while we're at it, we wonder if we wouldn't be better off going back to things we know. That said, it seems to be a good software of methods but not of design ... and I tear out the little hair I have left on the drawings
It's interesting to have to start implementing software these days. A lot of information available. If I have an opinion to give it is to plan a PDM with a dedicated server, even with 2 designers. If PCs are powerful in the case of large assembly and therefore of drawing greedy in computer resources. In the case of small assembly why not SW is up to the task and the machines will run easily.
If not, why Topsolid and SW, but not another such as inventor. I discovered it 3 years ago (after 20 years of SolidWorks) and to tell the truth, it's now the software that runs easily on any PC, even laptop. Very easy to upgrade when you know SW.
I practiced it ... 15 years ago now. So, it goes back a bit far in memory. The idea of changing was to have a software known to the designers in place. If you want to do a training course and not know too much about the software, you might as well stay with TopSolid: at least the database is created
It's true that sudden change is not always well received. But it's a fairly easy software to get to grips with. Not too resource-intensive. I just finished a project where the model was quite big, and SolidWorks rammed, on the other hand inventor did well. Well the Pcs with 32 of RAM and a sublayer of m... But indeed if you don't feel the change through the guys, it's not worth worrying. It's still a most important tool being the design. I rather like to say that it is in the design method that you have to spend your energy
Completely agree. And precisely, from my 1 month of experience, TopSolid is not a design software. He probably does a lot of things very well for machining, but for the design, there are too many failures and resourcefulness for it to be " fluid "
