Hello
Is it possible to put an equation in an assembly that means:
if the ØA is < to 6, the ØB will be = to 14 and if the ØA is > to 6 but < to 8, the ØB will be = to 17 and if the ØA is > to 8, the ØB will be = to 21
Thank you for helping me.
Hello
Hello, it's possible on several lines:
Let us (for example):
EQ1 = if ( "DiamA" <6, 14 ,17)
In the equation I wrote, EQ1 is only a temporary value, and I don't see anything like that in the attached image.
And why is there +2 at the end of the line?
In fact I have in my question ØA and ØB to explain the pb but the ØA corresponds to "Ø ext roue@Esquisse1@Pièce standard 5-link wheel. Part" and the ØB corresponds to "Ø ext@Esquisse1@063.13.01.Part" in my drawing.
The equations in the above message correspond to:
If "Ø ext roue@Esquisse1@Pièce standard 5-link wheel. Part" is:
- less than 6 then "Ø ext@Esquisse1@063.13.01.Part" = 14
- between 6 and 8 then "Ø ext@Esquisse1@063.13.01.Part" = 17
-greater than 8 then "Ø ext@Esquisse1@063.13.01.Part" = 21
Perfect, it works!
Many thanks!!
I'm going to complicate things a bit ! :-)
I now want this setting to work, I want the center distance of the purple piece to follow the Ø ext of the purple room. That is to say:
When the Ø is = at 14, the centre distance is 5.5
When the Ø is = at 17, the centre distance is 7
When the Ø is = at 21, the centre distance is 9
How do you write that?
That's another question but on the same subject.
