Can you fix a part during an animation in Solidworks Simulation?
Hi all
Let me explain, during a simulation study of my part, I obtain the results of constraints that I would like to animate in order to see the direction of the forces. I use S355 steel which makes the part very rigid compared to the forces applied here (I specify here because depending on the case the steel can be quite flexible ^^)  and when I launch the animation so I observe almost little displacement, I decide to amplify the scale factor of the deformation in order to obtain a visual result more telling (although rude).
My problem comes here, my part is fixed by anchor bolts to a virtual wall that is rigid and therefore should not move. During the animation of the amplified constraint, my part moves and makes observation difficult. And when the result is not amplified, there is a very, very slight displacement that is difficult to notice.
So do you know if you can fix a room during an animation?
Just as a reminder I want to get the deformed result with the result because I know that we can decide to display, in addition to the constraint, the distorted result or not.
Thank you all:)
