Broken wooden combi part
Hello,
I broke 2 functional parts of my combi wood machine. I am looking for a person or a method/explanation that will allow me to create them again. I took pictures, tried to model it from Hi3D but it's not great. I'm not very comfortable with CAD software. I attach one of the photos.
Thank you for your help.
WhatsApp Image 2026-08-24 at 20.07.39
Hello, several possible solutions:
  • you find a machinist in your area and you bring him the broken model
  • You can find these spare parts on the internet
  • You find a nice cartoonist in your area and you provide him with the broken model: what area are you in?
I hope some sides are not functional :face_with_raised_eyebrow:
The oblongs on either side are really annoying to access at the level of the V. It's a molded part in view of the shapes, but anything is possible. The price may surprise a little.
In 3D printing, there is a way that it is more cost-effective depending on the solicitation, a T6 treatment on the part to eliminate tension.
For the drawing with a diagram it is possible to make this piece for you
Edit: I expressed myself badly I can make it for you but you can make it in 3D, I don't have a milling machine on hand in my T1 :sweat_smile:
Hello and welcome to the David_HISSETTE forum,
To make this part it is also possible to do it from a scanner to create the 3D model, and to be able to print it afterwards, but I don't know the price.
Here's an example=>Geomagic for SOLIDWORKS | Artec 3D
… Good luck, @+.
AR.
I am 45 minutes south of Grenoble
Thank you for your answer.
I think it is possible to make it solid and then break through. This passage corresponds to the location of the clamping screw. I have other photos of course.
WhatsApp Image 2026-08-24 at 20.07.39 (3)
Correct dimensions on sketches via painted or other
I send you the model afterwards (I am missing the front and bottom part) to make the corrections to the drawing.
I will make you a basic model that can be modified later via the dimensions, if some dimensions do not suit you we change them. Do the rework according to your measurements directly on your part, my 3D scan doesn't work very well from here :face_with_peeking_eye: :sweat_smile:
To look on thingiverse, if part not already available (with machine ref for example).
If the part is fragile, potentially others have already redesigned it.
Or via the machine ref found a possible spare part on aliexpress or other.
Edit:
Give us the ref of the machine, possibly the spare parts are officially or unofficially!
