I've had a problem with the creation of virtual parts in an assembly since the installation of the 2025. The parts created do not have the personal part template settings. I searched through the options and compared all the settings with my 2023 version where it worked but I couldn't find the solution... Anyone have an idea?
Surely this comes in the system options and links to your Templates? When you change templates or their locations? Check links to items you've customized
Yes certainly in the options but I compared point by point all the settings of another version where it works, I didn't find any difference in settings. I also recreated a template with the 2025 version and checked the file locations...
There are the parameters of welded constructions, the zero on the right removed, the description of the sheet metal bodies... Yes, when I normally create a part, the parameters are those of the template, but when I create a new virtual part via the assembly, it loads the default part parameters. It worked fine on the 10 previous versions I used
Logically if your prtdot part model is well configured, any new part you create is derived from this model. It is possible (likely?) that your default prtdot template is the one brought by the new version (so with the default SW settings).
