Hello,
I found that the construction line insertion via this button inserts lines in strong strokes, which was not the case in all my previous versions.
I'm in V2025 and I redid all my settings from the V2025 base files, I may have missed something?
Hello;
Look at the settings assigned to line fonts...
See post with a rather similar question:
https://forum.mycad.visiativ.com/t/modifier-ligne-de-coupe-style-ligne-mixte-fin-epais/113904/2
Hello,
The problem is not there, my line style settings are ok, it's just when I go through this semi-automatic insert button that the lines are full.
If I go through the button, such as the one for sketches, the line font is ok but it's a little longer.
Hello;
See this (Solidworks 2025 SP3...)
Thanks for the info, I could use this method indeed but I don't use layers in Solidworks or in an exceptional way.
It's surprising that an option that provides for a line type and thickness, like for an axis, is ultimately useless because you have to go through layers ![]()
