Hello
I would like to have the following display of the dimensions with automatic tolerances:
Because currently when we put a tolerance we have this:
And here are our options:
Thank you.
Hello
Thank you.
Hello
Change the primary precision to .12 and for the font size click on tolerance at the bottom right normally (not visible on the screenshot)
The font size is the same, it's the capture that gives this effect. My problem is only focused on the 0s after the decimal point.
Your solution works but only for the case I presented, because on the next capture, the odds of 29.21 should be indicated at the thousandth and the tolerance at the tenth.
Hello
you have to go to your MEP and at the bottom right there is a tab and you have to go in and modify see PJ
In this case, change the same as nominal (which corresponds to the odds) and set the desired value. To my knowledge, the removal of zeros on tolerances is not possible if it's two digits it will display two digits no matter what
No, it's not that, because when I have 3 digits it won't work and also when I have one digit.
I would like me to be able to have ratings in this form:
Ø38 ±0.1
Ø38.1 ±0.12
Ø38.12 ±0.123
Ø38.123
For example, never with zeros on the right.
Edit: @cyril, so if I understand correctly, what I'm asking for is impossible? (If that's the case, it's really bad, because on inventor it works)
In fact, do you want the number of digits of your rating to evolve according to the number of digits on your side?
n digit => n+1 digit tolerance ?
It's not impossible, it's just that if you type them manually, it displays the value as entered and changes the digit number criterion by itself. At least that's the behavior I have in 2014.
I'm set by default to .12 on rating and tolerance (without linking them together)
