Problem creating slide stress
Hello,
I have a macro that inserts parts and creates constraints, it works great when I want to create slide constraints with a two-sided parallel slider, but not with a round slider. By doing it by hand it is not a problem, so to see where the problem comes from I created a simplified model with a round slider and a parallel and two corresponding slide constraints created by hand.
When I want to recreate a new constraint with the one previously created by hand, everything works fine, but not when I create it from scratch.
After investigation, it seems that the WidthMateFeatureData object used to create a new constraint only accepts 2 faces by default (when created with createMateData(11)) and " refuses " its modification with a single-sided slide.
Conversely, when it is created by hand with a single-sided slide, it " refuses " to be modified into a two-sided slide.
Do you know how to get the WidthMateFeatureData object to accept a round slider from scratch? (TabSelection attribute of size 1)
Or a trick to be able to create a width constraint with a round slider?
To be more precise, here is a piece of my commented code
'swCircularMateData : objet WidthMateFeatureData d’une contrainte glissière avec un coulisseau rond (créée à la main)
'swOldMateData : objet WidthMateFeatureData d’une contrainte glissière avec un coulisseau à deux faces parallèles (créée à la main)
Set swTestMateData = swCircularMateData 'récupère l'objet WidthMateFeatureData créé à la main
swAssembly.CreateMate swTestMateData 'crée la contrainte sans problème
Set swTestMateData = swAssembly.CreateMateData(11) 'crée un objet WidthMateFeatureData vide
'Recopie l'intégralité des attributs de l'objet
swTestMateData.ConstraintType = swCircularMateData.ConstraintType
swTestMateData.DistanceFromEnd = swCircularMateData.DistanceFromEnd
swTestMateData.FlipDimension = swCircularMateData.FlipDimension
swTestMateData.PercentDistanceFromEnd = swCircularMateData.PercentDistanceFromEnd
swTestMateData.TabSelection = swCircularMateData.TabSelection
swTestMateData.WidthSelection = swCircularMateData.WidthSelection
swAssembly.CreateMate swTestMateData 'la contrainte ne se crée pas
vTest = swTestMateData.TabSelection 'en inspectant l'attribut TabSelection, il s'avère être vide
swTestMateData.TabSelection = swParalleleMateData.TabSelection 'recopie l'attribut TabSelection de la contrainte avec le coulisseau parallele
Hello @Léo_RHODES1 , and welcome to this forum...
Indeed, the " CreateMate " function stubbornly refuses to create a " Slide " constraint with a slider with only a cylindrical surface.
If there is a solution, it is well hidden... :joy:
On the other hand, the " AddMate5 " function, declared obsolete because it is older, does the job.
The code below works on my basic example.
Option Explicit
' Génération d'une contrainte d'assemblage de type glissière, entre deux faces planes d'une pièce
' et une face cylindrique d'une autre.
' La fonction de l'API utilisée est AddMate5, obsolète, mais qui a le mérite de fonctionner...
    Dim swModel As ModelDoc2
    Dim swAssemb As AssemblyDoc
    Dim swSelMgr As SelectionMgr
Sub Main()
    Set swModel = swApp.ActiveDoc
    Set swAssemb = swModel
    Set swSelMgr = swModel.SelectionManager
    ' Sélection des faces dans l'ordre: 2 plans parallèles d'une pièce, un cylindre d'une autre
    Dim faceWidth(1) As Face2
    Dim faceTab(0) As Face2
    Set faceWidth(0) = swSelMgr.GetSelectedObject6(1, -1)
    Set faceWidth(1) = swSelMgr.GetSelectedObject6(2, -1)
    Set faceTab(0) = swSelMgr.GetSelectedObject6(3, -1)
    ' Application des Marks exigés par AddMate5
    swModel.ClearSelection2 True
    Dim swSelData As SldWorks.SelectData
    Set swSelData = swSelMgr.CreateSelectData
    swSelData.Mark = 1
    faceWidth(0).Select4 True, swSelData
    faceWidth(1).Select4 True, swSelData
    swSelData.Mark = 16
    faceTab(0).Select4 True, swSelData
    ' Création de la contrainte
    Dim swMate As SldWorks.Mate2
    Dim errorStatus As Long
    ' Le paramètre 0 après swMateWIDTH correspond à l'option "Centré"
    Set swMate = swAssemb.AddMate5(swMateWIDTH, 0, False, 0, 0, 0, 0, 0, 0, 0, 0, False, False, 0, errorStatus)
    If swMate Is Nothing Then
        MsgBox "Erreur AddMate5. Code : " & errorStatus, vbCritical
    Else
        MsgBox "Contrainte créée avec AddMate5."
    End If
Thanks for the answer! I'll make the changes on Monday morning and keep you informed of the result!
I've integrated this into my code and it seems to work well! To be seen in use!
Thank you, you have removed a beautiful thorn in my side!
