Hello
Here I have a problem with a radius dimension, when I change the diameter on which my radius dimension is here is what happens:
Here you have the basic plan I made:
and when I change the diameter:
As you notice I have my two rays that are no longer in the same place, they are staying where they were based.
A solution?
By doing Ctrl+Q, the error remains?
Yes, the spokes stay where they are.
and by doing the famous "reconstruct view" = hide the view, then show the view
And if not, by putting a projected view (not in section), then switching the view to wireframe, to dimension the shelves.
By changing the geometry, do the dimensions follow this time? (I think it's related to the cross-sectional view...)
Yes I also assume that it's due to the cross-sectional view, and for the hide trick show I just tried and not still nothing.
However I finally found a solution in the dimension settings, then in attachment line, in display of reminder/attachment lines I chose the attachment line with multiple break option which allows me to move the arrow as I wish and to link it with the radius.
Test passed, the odds remain attached :)
Thank you for your answer anyway.
A small picture to show the result?
Here is the photo when I put my ribs in the right places:
So there we can see that the spokes are attached,
and here is the same part whose diameter I just change:
To select the type of fastener it is here:
That's :)
