Hello
I have a problem with the "Print all views" function, when I do this, it filters the quantities of the BOM to the actors only visible on the screen. When you make a correct impression of the view in question with the "Direct Print" function, you have the complete quantities of the entire BOM.
The only solution I found is to put the actors I want to hide, visible but in "0" opacities so that they are taken into account in the BOM. But this is very tedious.
If anyone has a simpler solution it will help me.
Kind regards.
Solidworks Composer 2015.
