Hello
Since the switch to solidwork 2022, he has started to select imaginary lines (see photo). I can't seem to find the option for it to select only what's visible.
Thanks in advance
Slts
Hello
Try unchecking this option:
Kind regards.
I'm in 2022 SP5 version, maybe an addition on this version.
Do you have the same one?
I'm in SP0
I never use the SP0 of the versions, too risky in terms of bugs...
If you have the possibility, update to SP5.
Yes, do not work with an SP0. Wait for SP2 to upgrade to a new version.
Also since the redesign of the graphics tunnel, you need to check that your video card driver is up to date. Because on the 2022 version, and especially in SP0 and SP1, there were graphical bugs.
Ok thank you
I'll see with computers.
