Bonjour, je rencontre un soucis dans une macro sur un seul de plus de 20 postes depuis 2 jour (avant cela fonctionnait parfaitement).
La variable Set swPart reste vide au lieu de se remplir comme avant
Set swPart = swChildComp.GetModelDoc2() au surrvol swPart = Nothing:
Sub TraverseComponent(swComp As SldWorks.Component2, nLevel As Long, catSelect As String)
Dim vChilds As Variant, vChild As Variant
Dim swChildComp As SldWorks.Component2
Dim MyString As String
Dim swCustPropMgr As SldWorks.CustomPropertyManager
vChilds = swComp.GetChildren
For Each vChild In vChilds
Set swChildComp = vChild
Dim FileName As String
FileName = swChildComp.GetPathName
Debug.Print "Part Name : " & FileName
FileName = Left(FileName, InStr(FileName, ".") - 1)
FileName = Right(FileName, Len(FileName) - InStrRev(FileName, "\"))
MyString = FileName
Dim ActiveConfig As String
ActiveConfig = swChildComp.ReferencedConfiguration
Debug.Print "Configuration: " & ActiveConfig
If swChildComp.GetSuppression() <> swComponentSuppressionState_e.swComponentSuppressed Then
Dim swIComp As IComponent2
Set swIComp = swChildComp
Dim notRepetition As Boolean
notRepetition = swIComp.IsPatternInstance()
Dim swPart As SldWorks.modelDoc2
'Récupère la catégorie de la configuration active
Set swCustPropMgr = swPart.Extension.CustomPropertyManager(ActiveConfig) 'get properties
categorie = swCustPropMgr.Get("Categorie") 'get categorie
designation = swCustPropMgr.Get("Designation")
'Si la catégorie de la config active est vide on récupère celle du document
If categorie = "" Then
Set swCustPropMgr = swPart.Extension.CustomPropertyManager("") 'get properties
If designation = "" Then
designation = swCustPropMgr.Get("Designation") 'get categorie
End If
End If
Debug.Print "Catégorie: " & categorie
'If notRepetition = False Then
If catSelect = "FI" And notRepetition = False Then
folderName = "FI"
If (categorie = "Fourniture Industrielle" And Not (designation Like "STD*")) Or (categorie = "Tuyauterie") Or ((categorie = "Sans Catégorie") And (MyString Like "Bipod*")) Or ((categorie = "Sans Catégorie") And (MyString Like "Tripod*")) Then
compteur = compteur + 1
retVal = swChildComp.Select2(True, 0)
End If
ElseIf catSelect = "Visserie" And notRepetition = False Then
folderName = "Visserie"
'Debug.Print "Type:" & swPart.GetType
If (categorie = "Visserie") Or ((categorie = "Sans Catégorie") And (swPart.GetType = 2) And (Not MyString Like "Bipod*") And (Not MyString Like "Tripod*")) Then
rRetVal = swChildComp.Select2(True, 0)
End If
ElseIf catSelect = "Reconductible" And notRepetition = False Then
folderName = "Reconductible"
'If categorie = "Reconductible" Then
If (categorie = "Reconductible") And (Not designation Like "STD*") Then
End If
ElseIf catSelect = "Electricite" And notRepetition = False Then
folderName = "Electricité"
If categorie = "Electricite" Then
End If
ElseIf catSelect = "Produit" Then
folderName = "Produit"
If categorie = "Produit" Then
'Ligne pour exclure le composant de la nomenclature
swChildComp.SetExcludeFromBOM2 True, 2, 2
If categorie = "Produit" And notRepetition = False Then
End If
End If
ElseIf catSelect = "STD" And notRepetition = False Then
folderName = "STD"
If designation Like "STD*" Then
End If
'End If
End If
End If
Debug.Print
Next
Est-ce que quelqu’un aurait une explication a ce comportement très bizarre et soudain (pas de maj à prioris)
Au besoin la macro complète (ci-dessus code partiel)
CreateFolderByProperties.swp (118,5 Ko)
