Hello to holes,
Here I have a bug when I want to dimension diameters in the drawings I have the annotation <MOD-DIAM> instead of the dimeter symbol
How can I solve this problem that I didn't have on solidworks 2015 by the way?
Thank you
Hello to holes,
Thank you
Hello
This bug existed in the 2006 / 2007 versions if my memory serves me correctly. At the time, you had to go to the menus on the left, and delete the > character in the dimension text, and put it back on the keyboard right away. It worked.
Tell me if this is still the case.
Hello
A solution
Find the file named: "Gtol.sym"
http://help.solidworks.com/2014/french/WhatsNew/t_symbol_library_file_location.htm
Hello
Solidworks brings out the old bugs! -> SR-2009-09-53273
At the time we did this:
Close SolidWorks
Copy the C:\Program Files\Common Files\SolidWorks Shared\swvba.tlb file to C:\WINDOWS\system32
Restarting SolidWorks, the problem should not happen again
Edit: The file is here:
C:\Program Files\SolidWorks Corp\SolidWorks
I just had the same problem following the installation of the 2016 SP5
I found the answer illustrated in video here:
