Problem opening corrupted file
Hello everyone,
I try to open a file but it is corrupted and cannot be opened.
Unfortunately I don't have a copy, would you have an idea how to do it please?
Assembly or part?
For an assembly, try to change between solved and other state.
If it doesn't work or unfortunately there is nothing to do.
For my part, when this happens, which is rare, I have a backup of the server restored.
This often happens during a recording problem.
Recording not finished so data not fully saved, so file unrecoverable.
Edit: if it's not possible to open it, you can maybe open the read-only layout so that it doesn't update with a non-existent template because it is corrupted. (to recover the ribs that can help you redesign the part, if not too complicated)
Hello @frederickosiba
If by chance you had the backup option enabled in SW, you may be able to find a copy of the file in the folder defined in the system>backups options.
