Hi all
I have a problem with solidworks and my configurator.
Indeed, when I update my model after modifying my parameters in my excel file which transfers the information to the part family of a skeleton, I regularly get subsets in error.
I admit that I can't find the origin of this error. Because when I open the subset in error and force the rebuild, everything becomes correct again.
Despite using all these shortcuts, it seems that I can't force the reconstruction of all the sub-levels from the head assembly:
Are there other ways to force a rebuild down to the lowest level of subassemblies?
By the way, I don't know if the origin could be the fact of having many sub-levels or the way to manage the equations.
In the example above, I carry a parameter from the equipped cell to all the sub-levels in order to use it where I need it:
In the example above, I carry a parameter from the skeleton to the highest level that I transfer to all the sub-levels in order to use it where I need it:
Perhaps this is the principle that is causing concern? However, I have used it often and until then it worked.
Has anyone ever encountered this type of problem?
Thank you in advance for your feedback.
