Hello
How can I use the stamped function in the center of my part instead of removing material, I send you the file.
On the other hand, 2012 SP5 installation problem.
Kind regards
moule_3d.zip
Hello
Kind regards
Hello
First, can you be a little clearer?
Second, why wouldn't the material removal function be suitable?
Thirdly, what do you mean by "2012 sp5 installation problem"? :
- Which Operating System?
- What configuration?
- And above all, what a mistake??
Thank you;)
The material removal function does not suit me because if I but before folding the folded function does not work, I would like to put the stamped function after the engraving function on my part thank you
I'm sorry but I have a little trouble understanding.
I can see your assembly, but the grid I have inside is the 20*20 and not the 10*10 (I don't know if it matters) and in this set I don't see any component with sheet metal functions.
ok so from the photo you attached I think that the removal of matter you are talking about is the square shape in the center right?
it does not seem to open (logical for a stamping function)
For me I don't see any difficulty in creating a stamping tool, just create the "tools" part, and define the folder where it is located as a shape tools folder.
If you want a little more help try to attach your part to the "finished" state, and possibly the shape tools you have made if you have already made one.
