Problems with Sketch Relations (Constraints) - Diameter Dimension
A Part drawing is open,
A Sketch is active.
The sketch contains a circle.
The circle is selected.
I can't add a diameter dimension using any of the following methods
1. RelationManager.AddRelation(arrayOfObjects, swConstraintType_DIAMETER)
2. ModelDoc2.SketchAddConstraints("sgDIAMETER")
Is this a known limitation / bug or am I missing something?
Hello nirantar.vigyarthee,
What is your solidworks version?
I have 2020 SP4.
I don't know this problem. Give me a capture of your screen please, and i need know your document option, for help you.
Thank you.
AR.
Attention @A.R  , c'est peut-être spécifique à Solidwatch (que je ne connais pas).
May be I should have explicitly mentioned that this is API (programming) related problem.
I am able to create dimension but the mentioned methods do not work.
Maybe look at this : https://help.solidworks.com/2020/english/api/sldworksapi/Constrain_Sketch_Example_VB.htm
Thanks Sylk. I have already seen that. It does not include Dia Dimension.
Not sure what the sgDIAMETER is supposed to do but it looks like a reserved word without any effect for now...
However maybe this code below will doing what you want? :
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Sub main()
Set Part = swApp.ActiveDoc
boolstatus = Part.Extension.SelectByID2("Arc1", "SKETCHSEGMENT", 0, 0, 0, False, 0, Nothing, 0)
Dim myDisplayDim As Object
Set myDisplayDim = Part.AddDimension2(0, 0, 0)
Part.ClearSelection2 True
or
Dim swApp As Object
Dim Part As Object
Sub main()
boolstatus = Part.Extension.SelectByID2("Arc2", "SKETCHSEGMENT", 0, 0, 0, False, 0, Nothing, 0)
Thanks. I already used that method. I just wanted to confirm that the two mentioned methods do not work or I was missing something.
