Properties + Color
Hello
I would like to assign a part color per property to have a quick visual in the assembly.
example: Throughput: Blue Laser
Red Cutting
Yellow Shearing
etc...
Hello
In my case I use the material editor (below the volume body folder)
I use it to give a color according to the material and their thickness (wood, foam, aluminum, steel...),
But since you are for a machining process, you will have to do for example steel sheet - laser or steel sheet shearing ... (if the property of the masses is useful to you)
Question: Do you have parts that can have several types of process? (there it could get complicated)
One file per type of material then differs depending on their color.
Hello
You can create a library of parts with the gluers assigned to their typology, I did with the materials.
