Quantity in the BOM
Hi all
I'd like to know where SolidWorks is going to look for quantity in the BOM
To situate the question, in 1 multi-body part file (sheet metal and profile)
Right-click on 1 Soldered Parts List Item / Property
The tab : property of the list of welded parts will then appear
In the first window, find quantity in the BOM and then on its drop-down menu
For me (none or length)
PS I'm under SolidWorks 2015 install in 2013
I'm lost here:
"In the first window, find quantity in the nomenclature and then on its drop-down menu"
it's still 1 bug
Hello
Why say see right away that it's a Bug we haven't even tried to help you!
Could you specify if this happens to others, thank you in advance.
Have you at least created the length  column in the nomenclature
show us your nomenclature via a screen
or post it ;-)
so I put you -1
not to punish you but simply if another member goes by he will see that the best answer tagged is wrong
Yes, well his question is more than a year old... so it must have been a bug of an SP0 or something like that;)
