Hello everyone,
I take the liberty of coming to you because I have a very small question, to which I am sure you can answer me.
It turns out that I'm looking to shortcut an optimized copy, i.e. I would like to put it on an icon in a bar.
Thank you for your answer.
Hello
The first step is to save the optimized copy to a catalog.
Most of the time we stop there and use the default icon (the catalog path can be specified in the options).
To assign to an icon:
You have to publish the optimized copy at the catalog level (right click on it)
Then under Tools - customize:
- Create a new toolbar (if needed).
Under the order/catalog tab
the published copy must appear
Associate an icon with the order
Drag this command into the toolbar.
Wow!!
Thank you for your more than quick answer, thank you very much!!!
