Keyboard shortcuts
@Bart, try it you'll see it's not the right functions.
Obviously @Lucas is on the case, your question has been published for 10 minutes and he hasn't answered yet. You'll have your macro soon! :D
I click on Sketch, I select the face where I'm drawing, and by pressing my shortcut, the line only snaps to the midpoint of the segements. When I press the shortcut again, the function turns off.
@Bart, I'd really like it to select the middle point for me!!
If there is a macro to be done, I think @Lucas is the man for the job!
But you want the midpoint of a 3D edge and not the midpoint of a sketch edge!?
The time to click on your line, then on your macro, it will also go as fast to select the midpoint, right?
Here's your macro!
middle.swp
On my 3D, it's a matter of going a little faster and avoiding the right click! It's to save milliseconds but I can't stand to right-click for that!!
Well, I made a very stupid macro. And it works for me.
I click on an edge of my 3d, I press my keyboard shortcut which calls my macro, and the middle dot is displayed =)
Here
I agree with @David, I prefer a keyboard shortcut to spend my time having to move my mouse to a function. It's a question of perception and habit.
And then it rests the middle finger for special occasions...
See my post page 1, I attached my macro
Red cap!!!!!!!!!!!!!!!!!!!!!!!!!!
I'm putting it back on for fun;)
middle.swp
I'm a bit much off topic, but aren't your bending radii in your sheets a little small?
Off topic, but I agree with you@Fred
RED CAP!
BROKEN:
Personally, when I was doing plays like the ones mentioned, I proceeded in the same way.
Be careful, follow carefully. :)
Since my parts were subcontracted (so no way to know the loss at the fold) I did that, and I still provided the flow by specifying the dimension of the fold (I didn't completely side my part, I took on myself a method part).
So, for a sheet metal with 2 plies for a U-shaped finish, I made sure a minimum dimension of the inside of my U, but my design was such that it had no influence on the result: if the radius was as drawn (tight), my real U corresponded to my CAD U, and if the radius was larger, my U was wider!
Are you okay, have you been following? :)
Maybe @David has another reason...
I work in a sheet metal factory.
I make the plans for the workshop (Cutting, Bending, Punching, Welding etc...)
In general, up to 2mm, the radius is 2.6mm (V of 16)
above 2mm up to 5 the radius is 5mm (V of 32)
  @Bart Your macro is nikel !!!! Thank you
We can't hide anything from you!! In bending in the workshop we unfold everything in inner dimensions, so the coef K=0.01, we don't bother to put a bending radius on the one hand because we didn't do any tests with our bending machine and in addition we would have to recalculate a coef K by thicknesses!! Laziness prevailing over the bending radii, we leave it as it is, being careful as soon as there are parts close to the spokes!
That's the why and the how! But well done anyway!!
Thank you everyone!
Looking forward to @David ;)
I made an excel with my tools, my spokes and the power needed to fold.
With these three parameters, I know how to bend to the dicith of a millimeter =)
RED CAP!
Waooow  !!!!!!!!!!!!
First best answer of the month !!!
Soon the 18,000 points ............................:/
Red cap!
At least you've passed a milestone: you're at 10000 points!! :) and TOP 5.
Champagne..., good apple juice that stings for the moment!
In 10 years it should be good! ^^
