Hello
Anyone have an idea for how to have a ray on the surrounded part?
Either by sweeping or smoothing/removing material
it's up to you to create a 3D sketch by converting the entities
then you create on a plane perpendicular to this sketch at the end
a profile to remove the material
or variable or fixed fillet with a dimension after selecting the edges
Hello
intersection with surface to delimit the area --> 2 x bodies --> fillet --> fusion of the 2 bodies.
Hello
If you click on the edges and use the leave function, it doesn't work???
No. The leave function does not work
Hello
And by clicking on the order without propagation of tengeante of checkmark, what does it look like?
A.Leblanc can you put a larger picture to see the tree please..
Thank you.
Can you select your arettes yes or no?
if yes I reiterate
you create a 3D sketch
via convert entities
at the end of this 3D sketch you create a perpendicular plane
on this plan a sketch
You create a profile to make a mastery elevation that you force to this said sketch
Material removal scanning function
and it's done
Nice tutorial!!
I will try to follow this step.
Your solution is good except that I'm a novice is that I had a hard time doing something perfect. ☺
How stuck are you?
I can't put the 0.05 radius.
I can put a radius of 0.01.
I have to machine the shape of this part in negative and my smallest milling electrode is Ø0.1 so the corners will have 0.05 radii and I would like to represent my part as it will come out of the machining
Can you send me your part, or the area concerned?
Do you know that? If you already have your part and you need the mold you can use that.
Yes, I did that, but in a way. With the imprint function. But I find myself with the same problem in my footprint.
I don't really see the pb or I didn't understand what you would like to do.
Everything is good!! ☺
Thank you for your help.
