Retrieve a Configuration Name in an Assembly
Hello
I have an assembly of different parts with each one a configuration, I would like to make a macro to retrieve the names of the configurations of each part, to save the file with a defined name with its configurations.
I tried with the function: GetCustomProperty2, but I can't use it.
Thank you.
I don't really understand the goal...
If you have a lot of parts, the name of your assembly will be very long and too long? Did I understand your purpose correctly?
Hello
in fact, no, because my configurations have a relatively short name, such as "Ø16" (bore diameter). I don't want to get the name of the part, only the name of the config.
