Hello @ all
I search in vain
for M30x1.5
the minimum thread diameter
and minimum thread inner diameter
To be able to add this thread to the toolbox tapped holes
if I don't have this data he doesn't want to add anything
thank you in advance
Hello @ all
I search in vain
for M30x1.5
Hello
For M30x1.5 (with 6H/6h tolerance):
Minimum thread diameter = 28,323mm
Minimum Thread Inner Diameter = 28,376mm
thank you @ PhilippeB
I have the vague impression that in the data configuration of threads threads threads Toolbox
that he uses
Outdoors Minor Dia Max so 6g/4g6g for Mini Thread Diameter
internally Mini Dia min so ref 6h for Minimum inner diameter of thread
See attached copy
to compare would you have the values for
M 30x2
M30x3.5
For M30x3.5 :
Minimum thread diameter = 26.158mm
Minimum Thread Inner Diameter = 26,211mm
For M30x2 :
Minimum Thread Diameter = 27,797mm
Minimum Thread Inner Diameter = 27,835mm
Correction for the M30x1.5 :
Minimum thread diameter = 28,344mm
Exact @ philippe B
it's the refs that I think taken into account
I'll test it
Now my new ref is at the bottom of the list
to know how it will go now
without the need to "touch the ISO standard"
this thread already exists at DIN!!
exact @ Olivier 42
after checking.............. I hadn't seen ;-(
well it makes me a little swollen......... Enormously
impossible to retrieve for the creation of threads (tapping) the Din standard
and yet select in the standards for toolbox
I did add my new ref in ISO but I can't find it in the thread assistance
The only standards proposed are
inch die
inch tap
metric die
metric tap
SP4xx Bottle
and in these series no M30x1.5
(oh beginning, I hadn't answered, I had taken the question for a basic question from a beginner, I hadn't seen that it was you gt22, lol)
However, in your standard manager, DIN is activated, because it is not grayed out.
Do you select the right type of hole? See screenshot
otherwise, in the standards manager, you have to develop DIN, and check that the submenus are not "off"
Hi @ olivier and thank you ;-)
The fact is that I don't go through piercing assistance
(maybe I should) ;-(
since it is a part in revolution
I go directly via thread
since on the one hand I have to do
tapping and threading
I thought I could do it directly
but that's where I don't have the right standards in
tool thread specification type
inch die
inch tap
metric die
metric tap
SP4xx Bottle
PS: it's true that I wanted to try to have a visual of the nets
since it's supposedly possible ;-(
Hello, for the size to be taken into account in the drilling wizard it seems to me that it must have been added in the "thread data" tab AND in "Sizes".
Hoping it helps.
This (new) 3D threading function has no link (it seems to me) with "the database"
in file location, you will see or point the files, they are LFP with configs...
(it's smart at SW to have used LFP, lol...)
EDIT: by the way there is no control system (compared to the assistant with the database which has one) i.e. you can put an M1 on a Ø30!
and so, in the case of an LFP, it is not a "Missing Ref" but a missing config!
so, I advise to remove the M30 added/created in the ISO standard (because already present in the DIN)
GT22
you were able to add what you wanted in the LFP??
@ Olivier42
no it doesn't work the way I want it to
This is a subject to be explored in depth
it's pretty crazy that there is no link with piercing assistance ;-(
It's a total misunderstanding
and + tests thread/tap stresses
well no it's not possible
It's a shame I wanted to visualize the setting of a shock absorber
Calibration nut on the barrel to visualize the resistance
with spring compression via an animated spring
unclosed subject ;-)
The representation by this function is (it seems to me) only a simplified representation.
and yes no link with the database,
anyway now you know where to modify it to add configs, since it's only an LFP, I thought that was your first question?
Add images if necessary, to show what you're looking for?
