Regeneration in medium dimensions
Is it possible to regenerate a model in medium dimensions (in the case of non-symmetric tolerances) before generating a WWTP or a dxf in order to aim for the tolerance medium during the realization?
Or another method?
Frank
Hello Frank;
I don't know if it's possible, but in your case I'll save the model in config, for example in medium dimension as you want before generating your STEP.
If there is another solution I am taker.
If you have the Visiativ tools, Tolerance allows you to do it simply:
And indeed as @AR says, it's a config that is automatically generated.
To install the trial version:
https://mycad.visiativ.com/download-mycadtools
Otherwise via macro this one at codestack (not tested but reliable site):
Finally this subject still via macro (not tested):
For us, the 1st solution works perfectly as we have access to the Visiativ tools which we use for many other things as well.
Edit: a topic here that is a bit old but still valid:
