Hello
I have a library function of a crimped nut.
This is not a merged function.
When I repeat this function, its occurrences, and they alone, are.
I tried to disable or enable several options, without success.
Does anyone have an idea or a solution?
Kind regards
Hello
If your library function includes drilling the sheet metal as well as generating the crimped nut, then you need 2 repetitions:
A first function repetition for drilling
a second repeat for the volume body of the crimped nut.
Try it and see if the result meets your expectations.
that's how I work personally
a sketch with the option to segment into points, 1 point at the end and no point at the place where the 1st object was placed
repetition by sketch like this if you modify a point it does it by itself
Hello Silver_Surfer
I had found this solution that can work relatively well during a rehearsal with the help of a sketch. On the other hand, during a network repetition, it requires to put the same values on both repetitions. This is not very practical and a source of error when editing.
